Old member
I finished up the passengerside floor today with the sound deadener. Started at the fire wall right up against the AC box and went all the way back to the cab wall and corner of the cab. I did the back wall of the cab and doors several months ago. I ran out of material so I have to get more Monday. I hope all this is worth it. I'm going to try and get the drivers side done next week while I'm off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Jun 2012
Re: Sound deadener
Going to be installing a vintage air system sometime soon, was wondering should I install my sound deadener now on the firewall. (Cab is bare right now) Didn,t know if it would make the VA install harder with the mat all ready on. didn,t want to start taking any of it off after its on..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
Old member
I wouldn't install it under the box. Not much point I wouldn't think. Not sure how it would do inside there either. It would stay moist I would think all the time.
#4 | |
Re: Sound deadener
I still need to do my doors but, along with new door seals, it's done a lot to lesson the noise.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#5 | |
Old member
![]() Quote:
What is this for? What is the purpose of it? ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-08-2014 at 10:14 PM. |
#6 | |
Re: Sound deadener
![]() ![]() What you are looking at is MLV. Mass Load Vinyl. From what I've read, sounding should be looked at as a system. What I did first, was do use a dynamat type material with about 35% coverage, directly on the floor, toe board, and firewall, then the rear of the cab. This material does not have to completely cover, it their to primarily reduce/eliminate harmonic vibration which creates noise. This was followed by using a two sided aluminized closed cell foam material, which I used to completely cover everything I could reach. This is to cut down primarily heat/cold transfer. It's easy to work with. This is followed by MLV which is weighs about 1lb per sq.ft. It's very dense and very heavy. This material is used for sound proofing home theaters. It will reduce noise migration. It's stiff and doesn't like to bend in multiple directions, so I ended up using as few pieces as possible. This was place on top of the aluminized material. Of course I followed that with carpet padding and then carpet. So in my case it's a 5 layer system. If you'll google search MLV, you'll find several articles on the subject. Glad to hear that your doors sound much better. I still need to tackle my doors. ![]()
Old member
Thanks for the heads up. I remember reading on the Audio section about it now. I will have to check on it. I used fat mat and the bulbble wrap stuff and carpet so far I may do the MLV stuff as well.
I wear hearing aids so any unwanted noise I can cut out will be nice! ![]()
![]() Join Date: Jan 2014
Re: Sound deadener
Please explain and or show pics of how you do your doors
Old member
![]() I did as the local Stereo guy told me to do it. I cut a 12"x12" peice to go in center of door then 4 peices 6"x6" and put in each corner of the door as close to the corner as I could reach them. I also put a strip along the bottom on the inside skin of the door. Here is the link to how and what I used. ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=605236
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-09-2014 at 08:04 PM. |
Old member
Here are a couple of pictures I snapped before work tonight. Deadner then bubble wrap then carpet.
![]() ![]() Road Kill. ![]() Bubble wrap. ![]() Carpet. ![]()
Re: Sound deadener
Thanks for the info! BTW, nice truck Andy!
Re: Sound deadener
Also put some in the "b" pillars and in gap behind dome light. Also reach as high as possible into bedsides and put 12x12 sheet in area before and after wheel. Doors and floor make difference but these other make it even better.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#13 | |
Old member
Thanks, I try!
![]() ![]() Quote:
#14 | |
Old member
Thanks, I try!
![]() ![]() Quote:
