Old 03-09-2014, 12:42 PM   #1
Cohl
Cohl's Avatar
12 bolt to 14B FF width difference.
I have a 1970 Blazer with its stock 12 bolt. How much wider will I be once I bolt my tires back on the new 14b FF? Just trying to figure out if I need to change my wheel backspacing to compensate.
Cohl is offline   Reply With Quote
Old 03-09-2014, 03:34 PM   #2
ryanroo
ryanroo's Avatar
Re: 12 bolt to 14B FF width difference.
i dont know the exact difference if there is any. i think the 14 bolt is a touch wider than a 67-72 rear axle but not much. it also depends on the application of the 14 bolt. vans had wider rears and c&c and duallys had narrower wms to wms. some of the difference is in the hubs and some of them have different housings. i know the van housing is wider. i cant remember if the c&c housing is the same as a regular truck and the hubs are different or if the dually is the same with different hubs. one of them has a narrower housing. one has the same housing as a regular truck with different hubs.
so, i would say you can keep the BS the same.
here is my truck with a SRW K30 14 bolt rear. this would be the "standard" housing and hub set up on any SRW 14 bolt that came in any truck with a ff 14 bolt.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-09-2014, 07:15 PM   #3
Orange Crate
Orange Crate's Avatar
Please read here:
http://www.pirate4x4.com/tech/billav...ble/index.html
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 03-10-2014, 10:14 AM   #4
whitedog76
The Single wheel 73-87's were 67". The Dually rears were 63". The one I had was actually 62.75" to be precise. There were some differences depending on application. GM also used Dana70's throughout the era. You can use the Dually hubs from a 63" on a 67" to narrow it up. You will have to use a Van drum though.
I want to say the 88-98's were the same, they just had more reinforcing on the center section.
When you get into the 99 and newer, they get wider. Plus you start seeing the 11.5" rears.
whitedog76 is offline   Reply With Quote
