Old 03-09-2014, 06:10 PM   #1
scorpion1110
scorpion1110's Avatar
Power Steering Problem 72 GMC
Well folks seems every day I get a bit dumber.
I have a PS set up for my 72 GMC. Box, pittman arm, pump small water pump brackets, new hoses, pulleys. So today I decide to see how much of a problem I will have.
So I decide to bolt up the power steering pump and bracket and pulleys and start looking at alignment etc.
Tried to bolt up the cradle for the PS Pump and top bolt is fine, bottom off 1/2 inch or so from the hole due to it banging the balancer. Put a measure on the balancer and the diameter is eight inches. So I would guess my brackets are wrong? or should I go to a six inch balancer?
Any ideas?
Here is a pic of brackets and the bracket hitting balancer:
Love my wife, daughter, dog and truck.
The more money you make the less happiness you have.
My Build: The Little Tiger
http://67-72chevytrucks.com/vboard/s...d.php?t=630564
scorpion1110 is offline   Reply With Quote
Old 03-09-2014, 07:30 PM   #2
scorpion1110
Re: Power Steering Problem 72 GMC
Brackets in picture came off a 327 motor. Thinking they are different for a 350 due to balancer size?
Old 03-09-2014, 07:40 PM   #3
JimKshortstep4x4
I had a similar problem on my 65 SS which has the same PS bracket as yours. When I installed the 400 SBC with an 8" diameter damper I ended up grinding the bracket just enough for clearance as it looked like the bracket would be strong enough after I removed the material. I reworked the bracket in 1993 and the car has been driven on a regular basis during the summer since then without any problems.
This may not be the best solution but it works for me and no one ever notices the bracket at the many car shows the car is entered into.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
