Old 03-09-2014, 07:04 PM   #1
rickywideglide
rickywideglide's Avatar
gimp lowering
was planning on cutting front coils today didnt have all the tools,have to wait till tomorrow for u bolts for rear anyways,instead been messing around with this program. if only it was this easyName:  366.jpg
rickywideglide is offline   Reply With Quote
Old 03-09-2014, 07:35 PM   #2
YBNORML
YBNORML's Avatar
Re: gimp lowering
Cool truck, it will look pretty cool if you end up close to the photoshop. Heres a pic of my old 65' it had heated coils (done by the P.O.) which I wouldn't recommend. But is probably close to the height you are aiming for.
How much are you planning on cutting? I wouldn't cut much more than 1 full coil, that'll get you approx 2". If you want to go lower than that and keep any quality of ride you'll need to go to drop spindles.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-09-2014, 07:59 PM   #3
grghog
Re: gimp lowering
Is that a C20? I also want to drop mine (1965 C20) 4/6 inches - front/rear. Would love to know how you end up doing it.
grghog is offline   Reply With Quote
Old 03-09-2014, 08:26 PM   #4
rickywideglide
Re: gimp lowering
yea 64 c20, plan cutting 1 1/2 coil up front for rear was planning tj springs but havent decided ,friend gave me 3 inch blocks for rear so might try that and combo of lowered springs trying to go as low in rear without notch,which i think is 4-5 inches
Old 03-10-2014, 05:24 PM   #5
HDtech
Re: gimp lowering
It'll get there Rick. This is Paul. I joined up.
HDtech is offline   Reply With Quote
Old 03-10-2014, 05:44 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
Re: gimp lowering
C20 Or 3/4 ton springs a stiffer and you can get away with cutting a slight bit more then you can with 1/2 ton springs. I run 3/4 springs in my 1/2 ton lowered. Its a much better ride.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
