03-09-2014, 08:01 PM | #1 |
Need PS asdvice...again..where to buy...
Been trying to install my ps for 2 weeks. Had it done but alternator belt was hitting march bracket, so used 71 original ps bracket but the Saginaw pump was too wide and the bracket cut into it where it adjust in the back. So decided to use factory 71 pump from junker to see if that would work. I currently have a 2 row crank pulley and the pulley on that pump was about 1/2 a pulley to far out.
So now I'm back to the beginning. Thinking I should get the pump with the smaller neck, like the original 71, I think. I have 2 add on pulleys. So my question is... I need to know the best place to buy the original style pump. |
03-10-2014, 01:57 AM | #2 |
Re: Need PS asdvice...again..where to buy...
I bought a reman pump with reservoir from the local advance auto parts. The reservoir does not look exactly like stock but none of the pumps i found with reservoir from parts houses did. I believe they get the parts from the same mfr. (Cardone) and relabel them. In the past, I have always had issues with leaks when replacing pumps by buying them without the reservoir and trying to reuse my old one.
