Old 03-09-2014, 09:48 PM   #1
westong
front brake help...
Working on a 1972 K10......since i got the truck the front brakes have been poor.realy poor actually...when on gravel or a hard stop on pavement the rear wheels lock up and it feels like the front are weak. I replaced both front calipers and still no luck, when bleeding i have good fluid coming out with no air in all 4 corners and can get the front to lock up when tryig to turn by hand. I have bleed all 4 five times with no diffrence....old calipers acted the same way...any ideas.....thanks
westong is offline   Reply With Quote
Old 03-09-2014, 09:54 PM   #2
BMERDOC
BMERDOC's Avatar
Re: front break help...
Do you think the rear brakes need to be loosened up? Are they touchy to lock up? What does the friction material on the front pads look like? Do the front rotors look glazed?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-09-2014, 10:40 PM   #3
michael bustamante
michael bustamante's Avatar
I had the same problem in myk5 4wd blazer. Loosening the rear by hand helped a litlle but I had to replace the prop valve
1967custom
michael bustamante is offline   Reply With Quote
Old 03-09-2014, 11:13 PM   #4
westong
The breaks only work with your foot to the floor...both rear breaks lock up pretty easy ....the front rotors are somewhat rusty but both front pads are replaced. ....
Old 03-09-2014, 11:19 PM   #5
Gumby
Gumby's Avatar
all to common on many GM boards, I struggled with that for a long time in my Firebird. I replaced nearly every part till the last thing I did was toss some cheap $15 pads on it.
and I had brakes, as if the fancy high dollar pads I had on there, that still looked new would not grip at all till you got real hard on the pedal. [ who changes pads that look new, used a grinder to give them a fresh surface, no help ]
a good 5 years of crappy brakes and spending money yearly to try something different.
my long strugle
http://www.thirdgen.org/techboard/br...i-do-keep.html
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 03-09-2014, 11:31 PM   #6
BMERDOC
BMERDOC's Avatar
If you have long pedal travel and the rear lock up first I'd say the rear cup in the master cylinder is bad. The front reservoir is for the rear drums and the rear is for the front discs. The cup in the master for the front brakes is bad. This is the fundamental reason for a split system so that all the brakes aren't lost if one segment loses pressure. Replace the master cylinder. If the rears still like to lock up somewhat prematurely then loosen up on the rear adjustment until they do. You should be able to spin them and have the drum still want to spin on its own for almost a full revolution. Its an old tried and true method for adjusting the rears.
Nick Carter
Old 03-09-2014, 11:53 PM   #7
tcoop68
tcoop68
tcoop68's Avatar
You might check your proportioning valve that's the valve close to your master cylinder it's what regulates pressure to front and rear, you might also check and make sure you don't have a crimped line. Hope you figure it out. Coop
tcoop68 is offline   Reply With Quote
Old 03-10-2014, 01:53 AM   #8
WIDESIDE72
WIDESIDE72's Avatar
Sounds like a mc and/ or prop valve to me.
WIDESIDE72 is offline   Reply With Quote
Old 03-10-2014, 02:02 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
Fyi its "brakes" not "breaks" but i guess you figured that out, since you used the correct spelling in the thread. I know that you cant edit the title after posting. Im not an English teacher but have done some technical writing in the past and its a per peeve! (Although I have even "fat fingered" a post title myself in the past!)
