Old 03-09-2014, 10:29 PM   #1
jj72c10
Plug for clutch pedal rod in firewall
I converted from 3 speed column shift to automatic floor shift. Does anyone make the plug to seal the hole in the firewall that was for the clutch rod.
Thanks,
Jeff
jj72c10 is offline   Reply With Quote
Old 03-09-2014, 10:38 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Plug for clutch pedal rod in firewall
Thanks,
Jeff
It's called a clutch delete plug or plate depending on whether it is plastic or metal. GM made both.
Look here for the plastic ones:
http://67-72chevytrucks.com/vboard/s...d.php?t=535199
LockDoc
Leon
