Old 07-24-2003, 06:36 PM   #1
mitch23
Question Transfer Case
Could anyone please tell me how to determine my transfer case and also my gear ratio for a 85 GMC K1500?
mitch23 is offline   Reply With Quote
Old 07-24-2003, 08:17 PM   #2
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
it will be an NP208 aluminum case, chain driven, 2.61:1 low range..
if you're talking about axle gear ratio, well thats different.. you have to look it up on your RPO list or take the diff cover off of the axle and count teeth.. probably something like 3.08 or 3.42 or maybe 3.73
mike
mike reeh is offline   Reply With Quote
Old 07-24-2003, 10:51 PM   #3
ChevyThunder67
How you count the teeth is fairly simple. Just take off the the diff cover and make a mark at one of the teeth on the ring gear( big gear). Start from the mark and count all of the teeth on the ring gear. Next, count the pinion gear teeth ( front of the diff housing gear). Finally, take the number of teeth on the ring gear divided by the teeth on the pinion gear and that will give you your gear ratio.
Westley
2000 Dodge 2500 diesel
1992 Jeep Cherokee
1976 Chevy K20 smallblock
1967 Chevy C10 smallblock
1974 Chevy Nova 2dr.
ChevyThunder67 is offline   Reply With Quote
Old 07-25-2003, 08:36 AM   #4
rockman20
"The dude abides"
rockman20's Avatar
Probably stupid question here, but if you had a NP208 transfer case with the 2.61:1 range and 3.42 gears in the axles, does that mean you are running 6.03:1 when you have it in low range?
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 07-25-2003, 05:03 PM   #5
Jonboy
Slots go on anything!
Actually, it would depend on which gear the trans is in. First gear with a 700R4 is 3.06:1. Taking that, multiplied by the transfer case low of 2.61:1, multiplied by the axle ratio of 3.42 gives a crawl ratio of 27.31:1. I am pretty sure that is how it is figured. Conversely, in 2High, 4th gear (.70) and 3.42 the effective gear ratio is 2.39:1.
1974 Jimmy- 5.3/4L80e/NP241
