03-10-2014, 07:59 AM | #1 |
Quit if it's not FUN!!!
Need some HELP!
I'm trying to get my 350T/H column shifter working correctly. There is a "bellcrank" that the column rod is attached to. This connects to the "yoke" on the side of the transmission. I need a picture or illustration of all the various pieces ( spring, washer(s) cotter pin, etc). I can't tell what the holds the lower slot onto the yoke. Any help is appreciated.
03-10-2014, 09:43 AM | #2 |
Re: Need some HELP!
I have one picture. Maybe it will help.
03-10-2014, 10:16 AM | #3 |
The Older Generation
Re: Need some HELP!
Here's another: LockDoc
03-10-2014, 10:29 AM | #4 |
Re: Need some HELP!
Thanks, DOC,
That's what I'm talking about. Looking at the picture and the illustration, it appears the spring, washer, clip.. are on the lower side (toward ground). Is that correct/ And it looks like there is nothing on the upper side to contain the yoke. I can't seem to get mine to stay put. I'm thinking the yoke on the transmission itself is flipped. . I"ll keep plugging away. Thanks again Robbie
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) |
03-10-2014, 02:22 PM | #5 | |
Re: Need some HELP!
LockDoc
03-11-2014, 07:58 AM | #6 |
Re: Need some HELP!
FOLLOW-UP:
In the process of switching my 400 Turbo for a 200R4 O/D, the installer took the "yoke" off of the side of the 400, and when they put it on the 200, they installed it up-side down. The "bellcrank" came loose and lost all shifting. After two tries, I came to this sight for some HELP. Thanks to Leon "LockDoc", I flipped the yoke around and reconnected everything. So far, So good. Made it to work this a.m. and with any luck, I'll make it home this afternoon. . Thanks for the HELP.
03-11-2014, 10:00 AM | #7 |
Re: Need some HELP!
Quick Question. I recently started a new build on a 68 c20 Custom Camper. Internals and functionality is flawless but the body leaves something to be desired. Indiana truck...what can ya do?
I have an opportunity to purchase a good looking parts truck very close to home. 69 c20. The price is right. Will all of the body pieces fit my 68 c20 custom camper frame? Doors, hood, front and rear fenders, bumpers, bed, etc? I am a beginner and really don't have the capability of pulling the motor, otherwise, I would obviously do the opposite and just transplant the organs. Any advice you have would be much appreciated. Thanks |
03-11-2014, 06:46 PM | #8 | |
Re: Need some HELP!
LockDoc
03-11-2014, 06:50 PM | #9 | |
Re: Need some HELP!
If I were you I would copy your post and paste it into a new thread. You will probably get more answers. It never works very good to piggyback your question on a different type of thread... Just a suggestion. LockDoc
03-11-2014, 08:47 PM | #10 |
Re: Need some HELP!
All seems to be well, but I would like to find one of these: that would be the "bellcrank" in the middle of the picture.
03-11-2014, 09:11 PM | #11 | |
Re: Need some HELP!
I would post a WTB on the parts board. There have to be a few floating around.... LockDoc
