![]() Join Date: Mar 2013
converting cargo light to 3rd brake?
My truck doesn't have the cargo light but I've heard of others installing one. I think I could buy one from lmc or somewhere.
Has anyone ever converted them to a third brake light? I figured if I could candy the clear lens cover red, and get the right bulb in it, couldn't you just run a wire to the rear of the truck and hook it to the taillights? It wouldn't be a cargo lamp anymore just a brake light. Ive heard from others who have added a newer third brake lamp from a different car like a nissan...but I want it to look factory. Any ideas? I've also read some bring it to the white wire by the pedal.. |
Re: converting cargo light to 3rd brake?
I wish someone can help.. I am very interested in the same idea.
Will I ever finish my 1986 stepper.. |
#3 | |
The lights at the back of the truck are combination brake & turn signals. Connecting to one of those wires would cause the 3rd brake light to flash along with the turn signal on the side you tapped into. |
you could make a led board even and make it light up red on brakes and white on cargo.
Good thinking guys. I will do that. Red led board inside wired to the brake swir ch white wire and then ill still be able to use the cargo lamp.
i would build a board do it half red half white like the center red and outsides white. then you could cut on what whenever. could candy the center if you wanted it red too.
#7 | |
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
yeah you could use that or one off a newer chevy or dodge too if you wanted to go that route. just make sure its one that lays flat and isnt contoured to the cab like my 04. it think 07 ups 88-99 are flat if you want gm.
| Bookmarks |
