Old 03-10-2014, 01:25 PM   #1
hddoc
How Do I ?
How do I remove this knob ? Thanks Doc
hddoc is offline   Reply With Quote
Old 03-10-2014, 01:26 PM   #2
hddoc
Re: How Do I ?
The heater nob ? Thanks Doc
Old 03-10-2014, 02:05 PM   #3
PGSigns
PGSigns's Avatar
Re: How Do I ?
Should be a set screw in it I think.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-10-2014, 02:50 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: How Do I ?
Looks to me like a cable pull. I'd think you need to disconnect the far end of the cable, and remove the nut or clip that is holding the bezel to the dash and remove the entire cable assembly. If you can straighten the rod enough to reuse the cable, the best way to remove the knob is probably to clamp the rod in a vise, protected by wood or cardboard, and place a crescent wrench against the bottom of the knob and give it a couple of hits with a plastic hammer. All of the dash knobs on my truck as attached with JB Weld.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-10-2014, 04:32 PM   #5
hddoc
Re: How Do I ?
It is sitting loose on the dash with the bezel floating, I would be happy to use a clip if that is possible. The cable does pull out and is also a 3 speed switch. What kind of clip do I need to get it tight to the dash it does have treads on the shaft that comes thru the dash but without removing the nob theirs no way to get a nut on it. Thanks Doc
Old 03-10-2014, 07:28 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: How Do I ?
Can you see a cable attached?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-11-2014, 07:05 AM   #7
hddoc
Re: How Do I ?
Yes there is a cable attached and going to the heater door ,also as a switch housing behind the dash that the cable goes threw. and it all works, just is not fastened to the dash. Thanks Doc
Old 03-11-2014, 12:08 PM   #8
hddoc
Re: How Do I ?
OK My eyes SUCK ! Found a set screw on the nob, All fixed. Thanks Doc.
Old 03-11-2014, 06:11 PM   #9
61_FL_Apache
Who Me?
Re: How Do I ?
Nice job Doc!! We knew you could do it!!
Steve
2001 Blazer 4D 2WD
Old 03-12-2014, 07:12 AM   #10
hddoc
Re: How Do I ?
Thank You.
Old 03-12-2014, 10:09 AM   #11
hddoc
Smile Re: How Do I ?
Originally Posted by Woogeroo View Post
Pictures or it didn't happen...
*smirk*
-W
It happend Doc.
