03-10-2014, 02:12 PM | #1 |
Help ring and pinon p/n
Im tring to find out if this ring and pinion part number 3824446 will fit a 65 1/2 ton. The add says 63 to 64 but arent they all the same? Thanks mark
03-10-2014, 02:15 PM | #2 |
Re: Help ring and pinon p/n
63-64 chevy c-10's were 17 spline axles. 65-66 chevy c-10's were 30 spline axles. Same 12 bolt housings.. you must be talking about the NOS 63-64 3.07 gears on ebay? A lot of companies make the 30 spline gears....check into Summit racing.
I believe the GMC's were Dana 44's and not sure on the 3/4 -1 ton.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-10-2014 at 03:00 PM. |
03-10-2014, 02:56 PM | #3 |
Doesnt the axle go in the spider gears? Yes it the one on ebay. I just thought gm would be better? Thanks mark
03-10-2014, 03:00 PM | #4 |
That's a question for someone with more experience on rear ends than me. I believe the gears will work, its the axles that won't interchange.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-10-2014, 03:04 PM | #5 |
Your looking for part number 6250541 fits 65-72 3:73 12 bolt 1/2 ton
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
03-10-2014, 03:07 PM | #6 |
Can you explain the difference, try to educate my self, thank mark
03-10-2014, 03:07 PM | #7 |
Heres the part in question:
03-10-2014, 04:23 PM | #8 |
Well, Im guessing here but by the GM Part numbers AND my parts books in each case, the 3:07s and 3:73s do show a different part number for the ring gear, pinion is the same part number as 65 and up. So the ring gear could be cut different for the inside diameter or the bolt holes could be different to match up to the case, could be something else ? Im looking in later issue GM books and normally if it was the same they would have changed the part number to fit all. Hope this helps
03-10-2014, 04:25 PM | #9 |
also, and if you are looking for the 3:07s your looking for 6260537
03-10-2014, 04:48 PM | #10 |
03-10-2014, 04:54 PM | #11 |
Any reference for the 3817776 stamped on the pinion? I assume the 14 43 stamped in is for the 3.07 gear?
03-10-2014, 05:34 PM | #12 |
Correct, 3;07 pinion gear, the ring gear is 3817779 and OOPS looks like I need to edit what I said earlier, its NOT the ring gear that's different its the PINION and by what Ive traced it now to is the yoke fits 60-64 and 65-72 up is different so Im going to check the spline count on the front of the pinion
03-10-2014, 05:44 PM | #13 |
03-10-2014, 07:01 PM | #14 |
03-10-2014, 07:31 PM | #15 |
Not really , coarse spline is weaker , the fine spline is the stronger one
03-10-2014, 08:46 PM | #16 |
03-11-2014, 01:00 AM | #17 |
60-66 Nut
Those gears should fit any truck 12 bolt housing with the correct series carrier and the correct yoke.
