Old 03-10-2014, 03:23 PM   #1
johhnyboy26
need different gear ratio
I' got a 72 chevy with 33's, 4 inch lift, and a 350. i recently put a 700R4 for better cruising rpms. But I think the gears are little to high because it keeps shifting back and forth out of overdrive. What gears should i use?
johhnyboy26 is offline   Reply With Quote
Old 03-10-2014, 03:33 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: need different gear ratio
3.73, or 4.11 are my 2 faves. I have 4.11's with 31" tires and a 700R4.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-10-2014, 04:26 PM   #3
cool68
take a look at a rpm calculator online-project33.com
cool68 is offline   Reply With Quote
Old 03-10-2014, 05:12 PM   #4
Lee H
Lee H's Avatar
What gear ratio do you have?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-10-2014, 06:00 PM   #5
hugger6933
you may even want to consider 4:56 but with the tire height you need to run it threw the gear formula to see what the final would be in overdrive. [0.78:1]
hugger6933 is offline   Reply With Quote
Old 03-10-2014, 08:11 PM   #6
jocko
jocko's Avatar
Curious what you have now also. If it's hunting between 3rd and o/d, then it sounds like the combo of tire dia and o/d gearing are playing with your transmission's mind. Here's the cruising rpm for a 700R4 at 65 and 75 mph with 3 different gear ratios (all calculated with a 33" dia tire). Hope this helps you decide. Would be good to know what your current rear end is, if you know. K10 or K20? Welcome to the board! I'd say 4.10s are just about right - and 3.73 "should" be doable, but would be borderline lugging at the 50-60 mph zone.
Old 03-11-2014, 01:12 AM   #7
kwmech
overdrive and 33s-----4.56 all the way, maybe even a 4.88 if you plan on upping the tire size at a later date. I had a 1990 suburban a couple of years back that I put 4.56s into, that also had a 700r4. 'Burb had 31 inch tall tires on it and it still wasn't enough gear when I had to tow something. With a small block and a heavy truck the average engine like to spin between 2200- and 2600 cruising down the highway
Old 03-11-2014, 10:47 AM   #8
johhnyboy26
I'm not sure on the gear ratio i bought the truck as a project and finished it but never even thought about the diffs, if it's not the diffs what could be wrong with transmission?
Old 03-11-2014, 10:51 AM   #9
johhnyboy26
Thanks for all the replies, it really helps that people with knowledge about these trucks can give you the information you need, thanks
Old 03-11-2014, 10:54 AM   #10
johhnyboy26
I'm trying to put a factory tach in and i have an old cluster with a tach in it. What do i have to do to put this in and if it doesn't work where could i get a new tach?
