Is this it?
I got my sending unit and walbro pump today...is this it? All plug and play?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Re: Is this it?
is there a certain part number for the corvette style filter? i have a return less setup
![]() Join Date: Sep 2005
Re: Is this it?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Is this it?
cool, ill order it now
Slots go on anything!
Re: Is this it?
don't forget to put the sock on the bottom of the pump. There should have been a new one with your sender. I don't know if I would trust the worm drive clamps on your fuel line. You might want to replace them with fuel injection clamps that won't tear up the hose.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: Is this it?
thanks man, i got those clamps too...i did put that sock on the bottom...my fat hand was in the way...i was just surprised that section was that easy...ill swap the clamps out tomorrow...i was thinking it would be more complicated...i think I'm making the fuel delivery harder than it needs to be
Re: Is this it?
I did the same thing. I finally bit the bullet last week and bought a(nother) new EP381 pump, '87 fuel tank, and '87 sender. I have been trying to cheap out, and went back and forth between in tank and external pump. I have bought at least one of each, then changed my mind, and changed it again. Tank is in the truck now, and I refuse to pull it back out!
Re: Is this it?
mine isn't in yet...and with those clamps your talking about the permaclamp ones right? clamp once and done?
and what you mean? did you burn up a pump?
Re: Is this it?
I was really undecided. I have overthought just about every step of my swap so far. I started to use the in tank pump, but had non baffled tanks. I let my painter have that one, and bought an external pump. The more I thought about it, the more I liked the idea of the in tank pump. Thanks to Rock Auto, now it is all new.
Can you look at your sender and tell me which wire on the sender (grey or purple) corresponds to the red wire to the fuel pump?
Re: Is this it?
to be honest it looks like the both do
the way they go into the sender before they get to to the switch looks like they both go to the same wire...both positive...the other seems to be a ground
