Rear axle ID help
Long time lurker here and I need help ID'ing a rear axle on my 57 3200 truck.
I tried looking for numbers on it but there were none in the usual locations. I've done some research and I think it's from a mid 80's camaro, but I just want to make sure. Here are a few pics. Thank you in advanced |
Re: Rear axle ID help
Here's another pic. If I need to post more pics or info please let me know
Thanks |
Appears to be a Chevy 10 bolt, 8.5" ring gear.
If you can pull the code off of the tube, you'll be able to get the ratio. Unless its been swapped, then the o ly way would be to pull the cover and get the numbers off of the gear. 5 bolt obviously, probably 5 X 4.75" pattern |
Thank you DaveCt
