Old 03-10-2014, 10:59 PM   #1
matt_field
matt_field's Avatar
1968 k10 brake hoses?
Hey guys, does anyone know if there is a supplier for brake hoses for my 68 k10? I can't find the fronts anywhere.. I'm looking for original style. Not braided.
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 03-11-2014, 12:32 AM   #2
vectorit
What?
vectorit's Avatar
Re: 1968 k10 brake hoses?
If they are anything like my K20, I don't think anyone makes repro's.
The bit that is different, is the fitting to the wheel.
What I did was take my crusty ones to an industrial hose shop, one that caters to companies dealing with hydraulic and fuel hose needs.
I brought my stuff to them, and they matched the rubber hose perfectly.
Then cut off the fittings, and then welded on new crimp fittings.
I had the new ones made a few inches longer than stock, and couldn't be more happier with the results. Plus the cost was really reasonable.
These guys are a CA shop, but adding the link just so you get the idea of the type of business they run.
http://www.hose-man.com/
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-11-2014, 05:12 PM   #3
61K10
61K10's Avatar
if drum brakes napa carries them, but you have to use an adapter at the wheel cyl. the wheel cyl is 3/8 and the org was 7/16, at least on my 61. mine are 24" long.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
