Old 03-11-2014, 07:00 AM   #1
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
parking brake not holding
hello guys. I need help adjusting my parking brake. its been almost 5 years since my truck has been on the road and I can see the end in sight. just need the parking brake to hold to pass inspection and I'm good!!! how far apart should the main cables be from one another? (u know there is only one , but I'm talking about the one that pulls tension from the pedal and the other on the passenger side that holds the rear cable in place) right now they are pretty close together. I have adjusted the screw and all the cables are tight when the brake is engaged but it won't hold the truck in place? should I check to make sure the shoes are good or is it something simple that I've overlooked. thanks in advance everyone
FRANKENSTEINC10 is offline   Reply With Quote
Old 03-11-2014, 07:25 AM   #2
Gumby
Gumby's Avatar
Re: parking brake not holding
adjust rear brakes, all the parking brakes does is engauge them.
little slot hole in back of inspection plate to do that with wheels on and a flat head screw driver. Only turns one way, don't go crazy though, little bit and test.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 03-11-2014, 07:43 AM   #3
FRANKENSTEINC10
thanks Gumby!!!! I forgot all about that
Old 03-13-2014, 06:54 AM   #4
FRANKENSTEINC10
well I amnaged to find some time yesterday to get under the rear end to do some adjusting. come to find out my drums don't have the slot in the back to turn the adjuster. so I guess I need to go in from the front!!
Old 03-13-2014, 08:56 AM   #5
In The Ten Ring
I have the opposite problem! My truck has sat for 8 years now and the brake won't come off. LoL. I am going to take both rear drums apart and this time (did this last summer) I am going to remove the cable, free it up or replace, and actually fix it. If I can't get it...to the shop it goes even if I have to get her towed! I want to drive my truck again!
Dad will be so shocked to see his pride and joy coming down the road in all her 1972 glory.
In The Ten Ring is offline   Reply With Quote
Old 03-13-2014, 09:02 AM   #6
Gumby
Gumby's Avatar
often a rubber plug in the slot hole you knock out.
Old 03-13-2014, 09:03 AM   #7
FRANKENSTEINC10
I ehre ya there today is my dads 50th birthday and I want to go over and let this 454 breathe in front of his house. I might just do it and live with the ticket if I get one!!!!!
Old 03-13-2014, 09:05 AM   #8
FRANKENSTEINC10
I figured the sane thing Gumby. but not this one I am just going to do it from the front. I just hope the drum doesn't fight with me to get it off there
Old 03-13-2014, 09:30 AM   #9
cdowns
cdowns's Avatar
usually adjusting the star wheel will not help with the parking brake adjustment // you need to adjust the length of the parking brake cable to have a working parking brake
Old 03-13-2014, 09:31 AM   #10
Gumby
Gumby's Avatar
might wanna check replacement drum prices, often its so cheap anymore....
id have a 5lb mini sledge handy
Old 03-13-2014, 10:20 AM   #11
LockDoc
The Older Generation
LockDoc's Avatar
Are you sure you have all of the cable support brackets in place? I think there are some differences in years but this will give you some idea what you should have.
http://67-72chevytrucks.com/vboard/a...1&d=1309350537
If you take the wheel off there may be an adjuster in the front of the drum. Be sure and put a couple of lug nuts on backwards to hold the drum tight while you adjust the shoes.
LockDoc
Leon
