03-11-2014, 10:17 AM | #1 |
how wide of a rim can I get away with ?
I have a 78 blazer with a mild drop,flipped rear and notched,I,m doing some rust repair and have the wheel tubs out and was thinking of widening them just incase I want to run a wider rim.I, still running the leaf springs.
03-11-2014, 05:23 PM | #2 |
Re: how wide of a rim can I get away with ?
I think it would be close but you could get away with a 10 inch wide wheel with a 295 tire. I'm sure others have went wider though.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
03-11-2014, 09:54 PM | #3 |
A 10" wheel will work in the factory wheel well. THe blazers and trucks have good size wheel openings, so you can get a way with a good size wheel / tire.
03-12-2014, 10:36 AM | #4 |
Happy to be here
You can fit a 10" for sure. An 11" will be a tight squeeze, and a 12" will require mods to the outer fender liner.
03-13-2014, 12:35 AM | #5 |
I'm running 24x10 in the rear with a 295 tire with about a 3/8 inch space left to the inner tub on both sides give or take an 1/8 inch. One side is a little closer than the other but its due to the rear end not being centered.
03-13-2014, 01:02 AM | #6 |
i have a 10 inch with a 2" spacer on it.. so a 12 would fit.. just have to roll the lips and do some careful math.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
