Old 03-11-2014, 03:23 PM   #1
Grandpas72
power brake help
I have a 72 c10 shortbox that came with factory disc/drum setup. We want to add power to them to help pedal effort. Can anyone tell me what all I need to get to make this happen? thought about buying the master cylinder/booster setup on ebay but wanted to know if this was the best thing to do. Any help or links would be great. im searching but not finding what I need so far.
Grandpas72 is offline   Reply With Quote
Old 03-11-2014, 04:05 PM   #2
Lattimer
Lattimer's Avatar
Re: power brake help
You should need the new master/booster setup, firewall bracket, and connecting rod to the pedal. Then you need a fitting on the carb or intake for vacuum and a hose to connect to the booster. I got mine from a donor truck. I believe CPP sells a complete kit or there are custom firewall brackets out there. Might find the brackets on the parts board here also.
http://www.classicperform.com/Store/...ck/6772BBD.htm
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-11-2014, 04:06 PM   #3
Lattimer
Lattimer's Avatar
Its part # 6772BB2
http://www.classicperform.com/Chevy-Truck.htm#15
Shawn
Old 03-11-2014, 04:19 PM   #4
72bowtiestepper
If you can find the brackets & connecting rod to the pedal used here on the parts board, you can buy the master cly. & booster from a local parts store like NAPA for a lot cheaper.
72bowtiestepper is offline   Reply With Quote
Old 03-11-2014, 04:20 PM   #5
cool68
might check local Pick'N'Pull type wrecking yards and craigslist too for power booster core and correct bracket and pedal rod
cool68 is offline   Reply With Quote
