Old 03-11-2014, 04:48 PM   #1
Vandals909
Mounts ECE vs Dirty Dingo
I have a 71 that I will be putting an ls engine in and want to use electric fans and a/c. Would like motor in factory location.
early classic enterprises or the dirty dingo's?
thanks!!!!
What have you guys used with the best results?
Vandals909 is offline   Reply With Quote
Old 03-11-2014, 05:06 PM   #2
Billett
Billett's Avatar
Re: Mounts ECE vs Dirty Dingo
Can't say about A/C, but my cutthroat4x4 ebay adapter plates work fine and have plenty of room for electric fans. That is with stock I6 towers and Prothane mounts. Old style, not clamshell.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-11-2014, 05:56 PM   #3
solidaxel
solidaxel's Avatar
78 2WD clam shell electric fans 5.3 4L60E D D upper A/C Sanden for me, piece of cake!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-11-2014, 06:23 PM   #4
uxdesigner
I have the exact same question. Any pics?
uxdesigner is offline   Reply With Quote
Old 03-11-2014, 06:41 PM   #5
wgeyer88
I also used late 70's 2wd truck engine stand with DD mounts. You can position your engine over a wide range with this setup. I believe you can even keep the AC down low if you keep the engine far enough forward. Mine did not fit because I have my engine moved back as far as possible. It is basically up against the firewall. I will probably do a high mount AC as well.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 03-11-2014, 06:49 PM   #6
solidaxel
solidaxel's Avatar
What part ?
LS 3 4L70E
Old 03-11-2014, 09:33 PM   #7
Vandals909
Seems like everyone likes the Dirty Dingo for there adjustability.
How much further back are you able to mount the engine over the ECE mounts? Maybe 2 inches max?
Old 03-11-2014, 10:15 PM   #8
solidaxel
solidaxel's Avatar
I did not measure the distance, from where to where?
The 4L60E is longer than the TH350, because I had to move the cross member to the rear until the rear transmission mount met the mounting location. at that point I checked my column shift linkage and I aligned it with the transmission linkage mount and there is where it ended up. Tightened the bolts on the engine and it was in place. Just then I placed the drive shaft yoke in the transmission and it bolted up to the rear end, with 1+ of seal surface on the yoke.
I don't know about the ECE mounts I never looked at them
LS 3 4L70E
Old 03-14-2014, 05:17 PM   #9
jorgensensc
jorgensensc's Avatar
I used squarebody clamshells with dirty dingo mounts. I had a 402/th400 in it before. I slid the engine all the way up and reused my stock linkage from the th400 on the 6l80e, and didn't have to cut the driveshaft. Makes it really tight up next to the electric fans, but doable. If I had to do it over I would probably cut the driveshaft and move the engine back a little.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-08-2015, 04:20 PM   #10
Vandals909
Sorry for bringing up an old thread, time to get started on this swap.
Looks like everyone likes the Dirty Dingo mounts with the 73-88 factory clambshell mounts.
I believe others have used CPP sheet metal mounts for 67-72 with the Dirty Dingo mounts.
where is the best place to get a set of 73-88 clambshell mounts? Need v8 ones right?
Old 06-09-2015, 09:06 PM   #11
jessemthompson
I am using the ECE mounts with my swap. I have not reinstalled my front end, but it appears to have plenty of room for my radiator and fan setup as well as plenty of room between the engine and the firewall. So far I am pleased with my choice.
jessemthompson is offline   Reply With Quote
Old 06-11-2015, 03:39 PM   #12
70inbville
any pics of the firewall room? I want to hide my coils on the back of the head and have tried to figure out the right mount to give me about 2 1/2" in the rear.
70inbville is offline   Reply With Quote
Old 06-11-2015, 10:57 PM   #13
jessemthompson
I'll get some pictures tomorrow and post them for you.
Old 06-12-2015, 07:39 AM   #14
70inbville
Thank you sir!
Old 06-12-2015, 09:08 AM   #15
Hart_Rod
Hart_Rod's Avatar
Vandals PM replied to.
I have pictures of the ECE mounts and firewall room in my 69 Superburb thread.
Hart_Rod is offline   Reply With Quote
Old 06-12-2015, 10:36 AM   #16
jessemthompson
Here are some pics of my firewall room with the ECE mounts.
Old 06-12-2015, 01:33 PM   #17
dayj1
I relocated the coils behind the heads on the 4.8 in my '72. Details on the mounts and lots of pictures are here: http://67-72chevytrucks.com/vboard/s...d.php?t=668385
dayj1 is offline   Reply With Quote
Old 06-12-2015, 05:59 PM   #18
70inbville
Jessie and dayj1 thanks for the replies! dayj1 that is an impressive build you have there!! subd to that one for sure. thanks again Chip
Old 06-12-2015, 06:02 PM   #19
70inbville
I have pictures of the ECE mounts and firewall room in my 69 Superburb thread.[/QUOTE]
Rob thanks for the reply I have your build saved just hadn't got that far I guess. looks great and I will be calling for a pedal adapter soon!
Old 06-24-2015, 03:31 PM   #20
Hart_Rod
Hart_Rod's Avatar
Rob thanks for the reply I have your build saved just hadn't got that far I guess. looks great and I will be calling for a pedal adapter soon![/QUOTE]
No problem. Let me know.
