Old 03-11-2014, 06:46 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
Trans Id help
I have a 4l60e that the torque converter bolts don't line up with the flywheel. So my question is what do I have. a v6 trans?
61oshdr25193840
numbers from the tag on top of the trans
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 03-11-2014, 07:15 PM   #2
akdg87
akdg87's Avatar
Re: Trans Id help
older style 4l60e most likely, does it have a removable bellhousing or is it casted into the case of the trans? not a huge issue to make it work but some of the older (1993-95) 4l60's dont work well with the ls pcm.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 03-11-2014, 07:41 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Trans Id help
It had the removable bell housing
Build Thread
Old 03-11-2014, 09:25 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Trans Id help
So will this trans work behind the 5.3 with the vette cam that I have? or do I need to just go with a different trans that came from behind a v8?
Build Thread
Old 03-11-2014, 10:45 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trans Id help
Sounds like a pre-300mm 4l60e (aka a pre-ls 4l60e). They make convertors that have adapted bolt patterns, but they are dumb expensive, and really going the long way around the problem. Best bet is to find an "ls" 4l60e.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-12-2014, 12:49 PM   #6
akdg87
akdg87's Avatar
Re: Trans Id help
if yours has the one piece bellhousing that doesnt have the removable access cover on the bottom, you can make it work. Need to oblong the holes in the flexplate or buy a new flexplate (6.0/4l80e non dished, uses the old 300 mm bolt pattern still)
this has some decent info, there is a master swap guide on the same site as well: http://ls1tech.com/forums/conversion...nsmission.html
could you post a picture of your transmission?
build thread
2009 CTSV Sedan
Old 03-12-2014, 10:04 PM   #7
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Trans Id help
It is the two piece bellhousing. I'll try to get some pics soon
Build Thread
