![]() Join Date: Oct 2009
6 Lug disc brake using 88-98 spindles ?????
So i researched the tech articles and thought that I had followed them to a T, however I took the truck to get aligned today and with no shims in the top, its still 1.3 out. I used 73 C20 lower arms, stock uppers arms, 88 upper and lower ball joints and tie rod ends. Everything went together great, but you could see that the caster was way off when it went together but I thought that it would align out. Wrong. Any suggestions on what I did wrong?
Has anyone else ran into this? any help would be great, thanks |
Re: 6 Lug disc brake using 88-98 spindles ?????
I have heard of the swap but haven't come in contact with one yet. There was another thread the other day where the guy had the same problem. His camber was 2.2. Looks like although its a physical bolt in it can't be done because of the positive camber. I don't know of a fix for it...yet.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Without narrowing the upper a-arm,... I don't know an answer.
YOU are the second member to confirm this problem. We need to get the word out to all that think this is a money saving disc swap. Install a 1/2-ton lower a-arm and spindle with an aftermarket C10 6-lug rotor,... and you will be back in business. Of course you will have to swap the ball joints and tie rods back.
Makes the $229 63-70 conversion spindles look cheap.
Plus no one has ever confirmed that the 88-98 spindle geometry works with the 63-87 a-arm/steering combo. Let us know how it works out.
I am a little more than interested here. I have all the parts laying around my place from trucks I've junked and kinda been holding on to them for a 6 lug disc front change. I have two others that I have gone the other way and done 5 lug [both from 71-72trucks] and I do have the stuff to do a whole 73 up front cross member swap if need be but I liked the idea of the factory like 6 lug stuff. Without looking up the camber specs what is the range? -T- your out on both the caster and camber? Aren't the lowers different? I remember that the one I read called for 68 LCA's and that is what I have gotten for my swap. I know the Ball Joint hole is the same size[67-70/71-72/73-87] but I wonder if it is placing the joint in a different spot ? Someone wiser than I kick in here with some front end knowledge
Yes it does!! I'm so far into this with new everything that I'm going to do my best to figure it out. I have a simple idea but I need to test it first and check all the in ands out. Somewhere I have read that it was done with a successful alignment but of course can't find it now!! Might be worth a sticky to save some people some $$$$$. Just a thought
There was a burb on here with this swap, I'll see if I can find it.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#9 | |
I don't like using "used" front end parts when I do this brake/suspension rebuild,... so the cost "savings" didn't add up to me. EVERYONE says they want a 6-lug rotor they purchase locally. But really,... how often do you replace rotors? With companies like RockAuto undercutting almost every parts store in town,... or companies like Summit Racing selling CPP 6-lug C10 rotors cheaper than anyone with FREE shipping. The "local rotor" issue is over.
Hugger, not sure on the camber since he saw it wasn't going to work. The lowers should be the same 67-87 as for design. I'm going to measure tomorrow and report back
#11 | |
I found the truck I was thinking of, but it was just a rotor swap. Anyways it's on the first page of this thread. Post 17 I believe.
http://67-72chevytrucks.com/vboard/s...d.php?t=431073
#13 |
I think if you machined an 1/8" off the upper arm cross shaft surface that would buy you .5 but an 1/8" seems like a lot to me to take off. Just throwing ideas out there. You'd probably have to clearance the backside of the upper arm so it doesn't contact the frame too.
#14 | |
#15 |
The range is .8 to -.3 camber and 2.0 to 3.0 caster. He is really only about .5 degrees out but I have a big problem with positive camber.
#16 | |
![]() Join Date: Nov 2001
Very good point!
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#17 | |
Let us know what you find?
#18 | |
#19 |
ok, I said i would report back when i knew if my fix worked, and it did. However, I'm just simply going to say that if your considering using 88-98 spindles to do a disc brake swap, don't. I safely made mine work only because I am so deeply invested in it with new a arms, ball joints, rotors, calipers, tie rod ends, and a ton of time that I felt compelled to make it work. I plan to only run this for as long as it take me to get an air bag kit with upper and lower arms that I can use and still retain my 6 lug wheels. I will be glad to PM with anyone that is in the same boat as me as to how I made it work, but will simply say to those that are researching about the swap.....BUY a KIT!!!
Any suggestions on a Air bag kit with upper and lower arms?? |
#20 | |
The only place for a-arms and air ride that I would use. They should be able to hook you up with spindles and 6-lug rotors. Can you tell us all what you did to fix the camber issue? (did you remove the spacer between the upper a-arm and the frame?)
