07-24-2003, 11:19 PM | #1 |
help with fuel system problem?
okay i am having a problem with the fuel system. i can't get gas to the mechanical pump. i know the pump itself and everything after is fine (carb, filter, ect.). we broke the cam in by running a feed line out of a gas can into the pump and everthing worked perfect so its a problem with something else further back.
what i did was go from the factory set up with a return line, to a pump with just and in and out. i cut the old return line back at the dual tank switch valve and plugged it. it also had a charcole canister line that ran up into the engine compartment and whas just not hooked up b/c i have no emmsions stuff anymore, and it wasn't plugged, so i cut that line as well back by the valve and lef it open to vent, b/c thats how it was before. so why can't i get any fuel to the pump? i tried it with the gas cap off b/c i was thinking mabey vapor lock? i also unplugged the old return line and let it just vent and that didn't work either. my dual tank switch has never worked so i've just always used the passenger side tank which is the one its stuck on, so there should be no problem there. if i suck on the input line to the fuel pump i can get choked up with vapors so i know its not plugged or anything, but i haven't tried actualy sucking it all the way in my mouth. does anyone have a selector valve diagram, i know i hooked the feed back up to the right spot but it might be good to see a diagram just in case. can someone help me, i really want to be able to drive this thing around
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's Last edited by low 84; 07-24-2003 at 11:23 PM. |
07-25-2003, 08:37 AM | #2 |
You need to go pick-up a siphon pump and see if you're actually getting gas to the fuel pump. That would be my first step.
Scott Shelbourne |
07-25-2003, 08:43 AM | #3 |
i know i'm not getting gas to the fuel pump, if i run it from a gas can it will start right up and run fine, but when i connect it to the hard line running from the tank i get nothing, i just don't know why
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
07-25-2003, 11:24 AM | #4 |
Sorry, missed that obvious statement about the gas can I guess. :p
Somehow, it's not being vented correctly. You may look at how the older trucks are routed with only the in and out fuel pumps and duplicate that. My '75 had one line coming from the tank to the fuel pump (in) and one up to the carb (out). Then, it had one line from the charcoal canister that ran back to the tank (that was disconnected). Pretty simple if I remember right. The trank must have some kind of vent to allow for the flow but I'm not sure.
Scott Shelbourne |
07-25-2003, 03:09 PM | #5 |
I'm back with 2nd truck!
try this Ryan- Turn the ignition on but not to where the engine turns over. It sounds like the sending unit is not working or just has too much air in the line. Turn the switch on and let it fill up the line for a couple minutes. You can also check the supply line by taking it off the fuel pump and into a gas can to verify that the sender is working. If not then you have a bad sending unit or a bad wiring. Also check for any fuses that could have been blown. One more thing to look for is the conenction at the firewall by the column driver side in the engine bay. If you happen to have knocked it loose or out when cleaning the engine bay you may not be getting power to your sender. It looks like a small rubber boot with about 4 wires coming out of it and has the conenction made into the firewall.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
07-25-2003, 03:53 PM | #6 |
thanks for the help guys, now i've got some ideas of what to check, it really sounds liek your right about the sending unit brandon, i will check that connection, and i'm gonna siphon the line that goes to the tank to see if i can actualy get gas to come out of it, lemme see if i can get this thing to life w/o using a gas can, lol.
07-25-2003, 04:44 PM | #7 |
Ryan, check the fuses first.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
07-25-2003, 06:39 PM | #8 |
okay its workin. i was confused b/c of what someone told me a few weeks ago and i had the lines crossed back at the selector valve. thanks guys
07-25-2003, 09:42 PM | #9 |
5 day ban, learn to behave.
It wasnt something I said was it?
Glad you got it fixed but my suggestion was going to be to blow into the feed line and listen for bubbles.. mike |
07-26-2003, 12:36 AM | #10 |
Glad you got it worked out! I'll swing by sometime Sunday and pick up my hoist and maybe we can toy with the tuning some. I'll be in the '67 so you can finally hear how the Hooker's sound. I just need to knock the dust off of it first.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
07-26-2003, 12:39 AM | #11 |
sounds good man. just give me a shout whenever on sunday, i should be here.
