Old 03-12-2014, 02:47 PM   #1
Roger carlin
Rear end for a 71' C-10
Can anyone recommend a good 5 on 5 rear end for my 71' C-10 short bed? Preferably a pos-disc rear end. I've heard some of the late 90's 1/2 tons work but I don't know their width. Mine is 63 1/2 hub to hub and I want to stick with the 5 on 5 to match the front. Help, help.
Roger carlin is offline   Reply With Quote
Old 03-12-2014, 03:32 PM   #2
ulakovic22
Re: Rear end for a 71' C-10
I was just researching this as well, but the other way. I wanted to find the width of the 67-70 rear ends since I know the 71-87 are all 63". I believe that the later model rears are 65". It would be easier to just to a disc brake conversion on yours.
Anthony
'67 Shortstep (555/T56)
'67 Parts Truck (TBA)
ulakovic22 is offline   Reply With Quote
Old 03-12-2014, 03:34 PM   #3
Pro Performance
Pro Performance's Avatar
If looking for a factory rear that has disc and the 5x5, I would check out the Impala SS rear ends. I am not for certain on the axle width though.
Pro Performance is offline   Reply With Quote
Old 03-12-2014, 05:06 PM   #4
ulakovic22
Chevy
91-92 sedan
1566mm - narrow (all)
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications)
1598mm - wide (Impala SS - disc & B4U - drum)
Buick 91-96 & Fleetwood 93-96 sedans
NOTE: Fleetwood housing is unique to the application - 4-channel ABS provisions
91-96 wagon, all
1642.5mm
All 93-96 7.625" (ring gear) housings are 1598mm wide (Chevy sedan only)
Anthony
Old 03-12-2014, 05:08 PM   #5
ulakovic22
FYI, the stock rear end for those cars is a 8.5" with an Auburn Posi
Anthony
