Old 03-12-2014, 03:24 PM   #1
acemang
acemang's Avatar
Question ..........after 10 minutes of engine running
I came home and opened hood. and had a weird noise that I have not heard before. I cannot explain the noise but I have a 10 second or so video of it that the sound comes out clearly. Am I allowed to post a video here, or how should I do to it get to board members to get opinions?
A little pre video info. Temp outside is 50 degrees. Engine temp was 175 at time of trip end. Motor is a cadillac 472.
EDIT: Here is youtube link: http://youtu.be/8cWmO_0_90Q
It doesn't sound to me like standard engine ticking noises that you hear after shutting down an engine.
acemang is offline   Reply With Quote
Old 03-12-2014, 03:28 PM   #2
geezer#99
geezer#99's Avatar
Re: Question ..........after 10 minutes of engine running
Post it up.
Old 03-12-2014, 03:30 PM   #3
acemang
acemang's Avatar
Added youtube link
Old 03-12-2014, 03:31 PM   #4
Ilike 72"s
Those 472's are good quite engines. What do you mean by 10 minutes? On rebuild? Or transplant of a runner ?
Ilike 72"s is offline   Reply With Quote
Old 03-12-2014, 03:43 PM   #5
acemang
acemang's Avatar
Sorry just took it to sons school to drop stuff off. No new work done to it recently. Just noticed a noise that was new.
Old 03-12-2014, 03:45 PM   #6
Hugh Mongus
metal contracting?
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 03-12-2014, 03:48 PM   #7
acemang
acemang's Avatar
its almost like water bubbling but not coming from radiator or hoses
Old 03-12-2014, 04:02 PM   #8
Ilike 72"s
If way to low on water and the engine over heats and makes steam it will make a sound like that. Although you should see the hoses move and hear it even when engine is off --unless the thermostat is stuck closed. The other liquid is gas in the carb getting to hot. The last liquid is oil. If thats it your screwed.
Old 03-12-2014, 04:07 PM   #9
acemang
acemang's Avatar
I think you nailed it with the thermostat. Its a 185 and I think it had not opened yet as the temp was 175, I am just a nervous nelly. I have plenty of radiator fluid water mix 50/50. Oil is not burnt and is clean. Im guessing that you are right on the money.
Old 03-12-2014, 04:07 PM   #10
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Sounds like thermal expansion/contraction of radiator.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-12-2014, 07:26 PM   #11
Ilike 72"s
OR---the significant amount of energy within the engine associated with the intermolecular forces of the liquid state changing to steam at the expansion rate of 30600/18 At 100C .
Rrrrrrightttt.,,
Old 03-12-2014, 08:33 PM   #12
swamp rat
swamp rat's Avatar
I agree thermal expansion/contraction, Question is where, radiator, or possibly in the exhaust system.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-12-2014, 08:40 PM   #13
Milo's 72
Milo's 72's Avatar
Almost sounds like the spring in the choke assembly moaning as it heats up.
Milo's 72 is offline   Reply With Quote
Old 03-12-2014, 10:00 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Sounds like bubbles in a steel tube, almost like a wind chime. Are any of the heater lines metal, with a little hose at each end? Could be air burbulating in the system.
~Steven
Simi Valley, CA
Old 03-13-2014, 09:44 PM   #15
acemang
acemang's Avatar
After some great tips on here, I headed back to my man cave aka garage and investigated. After an hour I figured out the issue. I needed to treat my engine like a baby and burp the radiator. Once I did that the noise has gone away. it could have gotten bad so Im glad I heard the noise in the first place. Thanks for all the tips and advice.
Old 03-13-2014, 10:45 PM   #16
Willys47
Willys47's Avatar
Rrrrrrightttt.,,
No not quite but it does takes 970 btus of energy to change the liquid state to steam state, your going in the rite direction with your thinking
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 03-14-2014, 06:50 AM   #17
bigmac73
bigmac73's Avatar
are you baseing your BTU number off of atmosheric pressure at 14.7
remember the higher the pressure the more BTU required to boil
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-14-2014, 08:24 AM   #18
Steeveedee
Who Changed This?
Steeveedee's Avatar
The latent heat of vaporization is the same at any pressure. Raising the pressure simply raises the temperature at which vaporization occurs.
~Steven
Simi Valley, CA
