Old 03-12-2014, 07:47 PM   #1
500dallorbeauty
84 Chevy shortbed 4x4 won't go
I have a 84 Chevy shortbed that I just changed the tranny from 700r4 to a 400 turbo with np203 transfer case. I put a tourque converter from a 350 turbo in it and now the truck won't go over 35 mph. What did I do wrong!!
500dallorbeauty is offline   Reply With Quote
Old 03-12-2014, 07:58 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: 84 Chevy shortbed 4x4 won't go
Is it shifting gears? A 700 uses a cable to shift and a 400 uses a vacuum modulator. Did you hook all that up?
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 03-12-2014, 08:56 PM   #3
500dallorbeauty
Yes it is shifting changed over cable to vacuum.
Old 03-12-2014, 09:52 PM   #4
rs74
rs74's Avatar
Does it seem like it is slipping, revving up high? Might need more details.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-12-2014, 11:13 PM   #5
500dallorbeauty
Drives fine shifts fine until it gets to about 35 then motor bogs out and dies 305 all stock runs good
Old 03-13-2014, 08:05 AM   #6
cadillac_al
When the motor starts bogging, can you throw it in neutral and rev it? It sounds engine related to me.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-13-2014, 08:37 AM   #7
68post
I agree, could be related to a lack of fuel flow. Run it thru the gears hard to see want happens.
68post is offline   Reply With Quote
