![]() Join Date: Mar 2014
1972 k10 rear of rear leaf spring hangers
Hello I am currently building a 72 k10 swb truck from nothing but parts. My frame is almost all together but I am missing both rear of rear spring hangers. Does anybody know where I can find them or can somebody give me some dimensions and I'll fab them up. Thanks in advance.
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: 1972 k10 rear of rear leaf spring hangers
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
I called lmc today and they said they don't carry spring hangers any more for my truck. I've google searched them and I get the same answer "we can't get them anymore".
Are you looking for these? P/N 34-0036?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=152
No that's the shackle assembly. I need the spring hanger that the shackle bolts to. You can see the part I need in the picture but no part number
Depending on your plans you might look into a shackle flip kit.
It reverses the rear suspension from a tension to a compression shackle and gives about a 4" lift. Since these replace the shackle brackets it could be a solution if you were going to use rear lift springs or blocks. http://offroaddesign.com/catalog/shacklekit.htm
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-12-2014 at 08:45 PM. Reason: all better now |
Sorry… I thought you were looking for shackles. The rear spring hangers are riveted on. What happened to yours? Here's a picture of mine from a Skyjacker lift kit leaf spring installation.
Dan I bought this truck as a basket case. The guy started to redo the truck and lost interest. The guy disassembled the whole frame. I mean every bracket and crossmember was off the frame. I started out with 2 frame rails and a pile of brackets and cross members. I have all the brackets accept for the rear spring hangers. That picture shows exactly what I need.
Tim, I looked into the shackle flip but I got 6" lift springs for the truck. I'd end up with 10" of lift in the rear if I read ord's info correctly. I just didn't want to go that wild of a lift on this truck.
Then just use a set of 2-1/2" rear springs with the HD shackles.
Better yet just become a subscriber and post a "want to buy" ad in the classified section.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#11 | |
How do I become a supporting member? I'm new to all of this.
#13 |
GM shows the same service replacement part 3933332 (2 reqd.) for 67-72 K10-20 and K Blazer.
#14 |
Tim, your saying all I have to do is go to a Chevy dealer and get these ordered
#15 |
I'd post in the wanted section as well. You might find a member who has done a shackle flip and has the original hangers still, or someone who is thinking about it and could use a few bucks to help make it happen.
#16 | |
However if you kick up a part that would be the number. More to the point were the vehicles that all used the same replacement part. You may find a good "set" by getting singles off of two different vehicles. A quick Google seach of the P/N showed only my post here and gm parts wiki. GMparts direct does not show it in the automatic system either.
#17 |
![]() Join Date: May 2008
I know this is not the right area to bring this up but i have a set of those factory hangers. My truck has the off road design suspension parts under it. I'll more than likely list them in classifieds at some point . I'll have to follow the rules and list them for everybody to see.
#18 | |
#19 |
How do I become a supporting member? Not trying to break any rules here but I'm very interested.
#20 |
In the top header, click on "Subscribe". There are options for you under the "Premium" category for you to be a supporting member. Or if you prefer other levels, those options are available as well.
#21 |
Thank you Dan. I'll do it tonight
#22 |
Well I posted my want to buy add. Thanks for everybody's help.
