My truck came origonal with a saginaw 3 speed (on the tree) and a 250l6, it got swapped for a Built up 350 and went through 2 saginaws, took the 350 out and i am in the process of putting the l6 back in. BUT, i dont have a transmission. i was given a th200 or 200 metric. will this setup be okay? how will it bolt up and perform? This truck has literally burned a hole in my pocket but it means too much to me to get rid of. and what about a shifter for the automatic? Please help me guys lol. And a pic of my engine, just to share.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
![]() Join Date: Oct 2013
Re: Someone please point me in the right direction.
try asking at phoenixtrans.com and bowtieoverdrives.com also, to help figure out engine RPM search for calculator at project33.com
Take a hunt around on this website. There are some useful articles.
https://www.novak-adapt.com/knowledg...shift_info.htm
Cameron 1984 Chevy C20 Custom Deluxe |
thanks guys, i just wonder how much trouble a t5 swap would be...
200C is a light duty transmission not really designed for a truck. You can use it for a while. It may require driveshaft length change. You MUST wire up the converter or it will get hot. A factory automatic column can be adapted, or a floor shifter.
3 speeds are cheap here. Cost more for a clutch LOL. There are several T5 swaps, biggest issue seems to be getting a WC T5 and relocating the shift tower. Might check the j-yards for a Saginaw 4-speed too. If you're goign to go auto, TH350's are stil plentiful and relatively inexpensive, and 700's can be had reasonable. I occasionally wil run accross a 2004R (think olds powered caprices out of the late 80's, or Monte Carlo's).
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
thanks for the help guys i really appreciate it. but i ended up going to a huge junkyard in king and pulling another 3 speed saginaw for 225$ does anyone know the size and length of the flywheel to crank bolts?
| Bookmarks |
