Old 03-13-2014, 08:42 AM   #1
Claytona08
Claytona08's Avatar
What engine?
Trying to determine what year model and size engine I have. I was told it was a 350 but just trying to verify. Here is a pic I took. Stamped 28GM 3970010. Any other number I need?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 03-13-2014, 09:01 AM   #2
Cherub
Cherub's Avatar
Re: What engine?
I asked the GOOGLE and this is what it said....
3970010 is the block casting #. That # you listed was used on all of chevys 4.000"
bore engines
Look on the right cylinder block in from of the head. There's a machined surface and the engine codes should there if the block has not been milled. Should be 2 set of characters, one it the engine code and the other the VIN derivative. Look something like the following.
T1024TFD engine code
If the first letter in the suffix is the letter T, its a truck engine. C its a car engine.
hope that helps cheers
Cherub is offline   Reply With Quote
Old 03-13-2014, 09:10 AM   #3
Claytona08
Claytona08's Avatar
Re: What engine?
bore engines
Thanks for the info! I'll try and get those numbers this evening.
Old 03-13-2014, 10:51 AM   #4
geezer#99
geezer#99's Avatar
Re: What engine?
Look here.
http://www.nastyz28.com/decode.php
Old 03-13-2014, 02:49 PM   #5
Claytona08
Claytona08's Avatar
Re: What engine?
Originally Posted by geezer#99 View Post
Ahh thanks Geezer!
Old 03-13-2014, 04:31 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What engine?
Hi welcome I have the same numbers on the back...
350-010 blocks
some feel it containing more "nickel"content,makes the block stronger
some find 2 or 4 bolt mains are possible
the "orange" block finished up in 78,but some are blue
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-13-2014, 04:31 PM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: What engine?
1972 350 ls9
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-13-2014, 04:50 PM   #8
Tdubbyount
Tdubbyount's Avatar
Re: What engine?
Thats a 327/350 cast. Ive got two 350's with that casting. One's a two bolt. One's a four bolt. They're the "high nickel" blocks, supposed to run a little cooler. Mine was .060 over, i could run it on a 95 degree day through the dunes all day long and never touch 200 degrees. They seem to be one of the most desireable 327/350 blocks.
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one.
1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose.
Tdubbyount is offline   Reply With Quote
