Exhaust system needed
I am looking for a bolt on dual exhaust for my 68 1/2ton short box 4x4 .
It will have a 350 engine , the transmission is a 4 speed Rockwell Unit . I have not been able to find anything with that tranny available Anyone ? One other thing , I will be installing headers , best brand and fit ? |
![]() Join Date: Jul 2010
Re: Exhaust system needed
Once you put headers on you are almost always looking at a custom or semi custom exhaust. Add to the mix that you are dealing with a 4x4, you will not find a suitable dual exhaust. I used the builders kit that summit sells, a 2.5 inch mandrel bent kit that I put together using flow master 40's. I only had to go to the muffler shop for one little z bend to get around the 221 tcase. My exhaust exits out the rear.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
