Old 03-13-2014, 04:45 PM   #1
JointTech
JointTech's Avatar
Fix a horn
One of my horns doesnt work. Hooked it to 12v and ground and it made a small squeak and then nothing. The second horn seems to work fine.
Are they different tones in each horn?
Is it possible to fix a horn? A new one is only $20 but im sure its a cheap POS and Im in a slow time on my truck anyway
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-13-2014, 04:50 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Fix a horn
Squirt some wd40 in it. I've brought a few back to life this way
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-13-2014, 04:51 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fix a horn
X2 on the WD40. And yes, two tones, one high & one low.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-13-2014, 04:55 PM   #4
JointTech
JointTech's Avatar
Re: Fix a horn
hmm they look the same. any way to tell which is which? I already took them off and have no idea which was where.
judging by the whimpy sound id say the high tone works but im not sure.
ill try the wd-40 on the broken one.
note to others, dont sand blast the horn. Im still shaking this dang thing to get the media out... doh!
72 C20 Long Bed
Old 03-13-2014, 05:13 PM   #5
jabborabbo
jabborabbo's Avatar
Re: Fix a horn
The high note horn will have an H in a circle on it. In addition to the WD-40, diddling with the adjustment screw can help, as can a few whacks with a rubber mallet - I brought a high note horn back to life using these techniques.
jabborabbo is offline   Reply With Quote
Old 03-13-2014, 10:18 PM   #6
swamp rat
swamp rat's Avatar
Re: Fix a horn
Whatever you do don't pour Coke in it!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
