Junior Member
Bed wood refinishing options - 5 year test
Came across this while looking for bed parts.
http://www.mar-k.com/final_summary.aspx Wish they'd have done a 'linseed oil wipe down every so often' option. Looks like it's impossible to keep a clear finish looking good on a daily driver.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle Last edited by stomper; 03-13-2014 at 11:57 PM. |
Re: Bed wood refinishing options - 5 year test
Interesting. thanks
______________________ www.northeastrodrun.com |
![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Just a thought, but has anyone tried outdoor grade Danish Oil?
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
Pine it is with option 9. Pine boards, coated with three brushed coats of Pelucid three hours apart, cured 4 days, block sanded, and sprayed with three coats of Minwax Helmsman Spar Urethane.
or Stomper if you could start the test for the 'linseed oil wipe down every so often' option that would be great. I probably won't get around to doing it for 2 years ![]()
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
To bad they didn't do any with automotive clear coat only. I paint homes for a living and on the exterior wood doors I use automotive polyurethane and I've had them around for well over 5 years without any peeling or cracking.
1970 GMC |
CAN'T FIX NOTHIN
I was thinking automotive clear too ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
I plan on installing my wood bed when the weather breaks. Very useful info. Thanks for posting
Great info, thanks for posting. I've been really curious about the best option.
Great article. Thanks for sharing. Long gone are the days of soaking the planks in used motor oil.
We just have to live with the fact that wood beds are a maintenance issue, no matter what. Mine is white oak which I hit with sand paper, steel wool, and PolyShades 1-step each spring just before the truck wakes from winter hibernation. Going on 8 years of abuse and still holding up pretty well. pic = ![]()
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() Last edited by GRX; 03-14-2014 at 03:12 PM. |
I was trying to figure out what I wanted to do with my bed wood and when I found out that 67 was the last year of black wood I thought I'd go this route and make it look factory with a twist. This was the test that solidified it for me when I found it.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
I'm a better wood worker than mechanic and I get jealous every time I see these beautiful beds. With no garage and the Texas sun I opted for a bed that a quick wipe down of Armor All makes it look like the day I installed it.
Figure out what you want--then figure out what you are willing to give up to get it. |
#12 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#13 |
![]() Join Date: Apr 2010
I used oil stain then oil based polyurethane. Gave the wood about 3 montages, then scotchbrited it and hit with 2 coat automotive clear. Mines not a daily driver, but that's how I did mine. If you rush it the auto clear will react and "pop"
