Quit if it's not FUN!!!
Lokar column shifter linkage
Anyone used this shift linkage in "our" trucks?
. http://www.jegs.com/i/Lokar/625/ACA-1800/10002/-1 . Thinking about going that way....Looking for some input. Thanks |
Re: Lokar column shifter linkage
I used this item. Easy to install, cut to needed length, bendable to get around things, really tightened up the shifter feel.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Oct 2005
Me too......worked great!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
I used this same kit on my CST. It did tighten everything up...unfortunately, on mine, it transferred some vibration into the shifter while driving. I went back to the stock linkage.
No complaints about the Lokar quality though....they make really nice stuff.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
Work's great on mine.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
I was in the process of ordering this linkage this weekend. I never considered it transferring vibration. Has anyone else experienced this problem?
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#7 | |
In defense of the Lokar linkage, I think a lot of my vibration was from using a urethane transmission mount and I also had a Gear Vendors overdrive hung off the back of the transmission so maybe it vibrated more than a normal install. I just found that the OEM linkage had some slop built into it and it worked better for me.
![]() Join Date: Apr 2010
I used this on mine when I installed a 700r tranny. Works great for me.
laying low
![]() Join Date: Mar 2001
It looks nice. Being a straight link from column to trans allows some vibration and engine/trans torque movement to transfer to the shift lever on the column whereas the OE linkage design allows any trans movement to go almost unnoticed in the cab. Also the OE linkage has a couple of rubber bushings to absorb some of the vibrations. The shift lever doesn't tend to move up and down when you mash the go pedal.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Dec 2012
used it on last two builds Works great
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
I set mine back up stock like Boogs', but I was unaware that it needed rubber bushings. Must have got lost through the years. All the holes and slots where there's movement got hollowed out pretty bad, so I welded them all up and redrilled. It tightened up and feels pretty nice, but I still like the idea of one rod like Lokars.
Has anyone tried the cable style that Lokar also makes? http://www.summitracing.com/parts/lo...4/applications Any benefit between the rod and cable? I would think the cable would eliminate any vibration. ![]() ![]()
subscribed
Figure out what you want--then figure out what you are willing to give up to get it. |
