Old 03-14-2014, 01:22 PM   #1
Fatherof3
Fatherof3's Avatar
Front inner fender clearance
Been searching for examples of "At what point do you need raised inner front fenders for static low?".
I know tire size is a huge factor, I have a 71 C10, will have 235/70/15 tires and CPP 2.5 spindles and trying to figure out how much lower I can go before inner fender clearance becomes a problem (will make changes to deal with LCA to ground clearance but trying to find out about the fender well issue right now)? Thanks
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 03-14-2014, 01:44 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Front inner fender clearance
I think anymore than 5 inches in the front and you run into problems.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-14-2014, 06:11 PM   #3
stomper
Junior Member
stomper's Avatar
Those tires aren't that big. Just a guess but I'd say your crossmember will hit the ground before your tires hit the inner fenders. I am currently running 255/40/20's with a 5+ static drop with no problems. Also just fit cupped LCA's and I'm not certain yet I will have to do anything with the inner fenders when the crossmember is laid.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 03-14-2014, 07:17 PM   #4
AZBIG1
305-40-22's on 10" wide wheels. They are 32"s tall. Roughly 3's dropped(cut) coils. no problem. 6" backspacing. Have bottomed out without tires hitting.
AZBIG1 is offline   Reply With Quote
Old 03-14-2014, 07:18 PM   #5
Fatherof3
Fatherof3's Avatar
Crossmember will be out of the way
Old 03-14-2014, 09:20 PM   #6
stomper
Junior Member
stomper's Avatar
If you can take care of the crossmember I'd think you can deal with the inner fenders when you get there. With 235's on my stock steelies, I don't think the outer fender or hood hinge will be in the way - just the inner. I know you're looking for real experience but that's my 2 cents.
Old 03-15-2014, 12:47 AM   #7
sanford66
sanford66's Avatar
Lowered my 72 about 4.5" to 5" it the front. Truck had 8" rallys with 235/70/15 tires, and they rubbed whenever I hit a bump. Swapped those out for a pair of 7" rallys with slightly smaller tires [don't remember size right now] and haven't had any clearance issues since. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 03-15-2014, 10:38 AM   #8
Fatherof3
Fatherof3's Avatar
Thanks Guys!
Old 03-15-2014, 11:07 AM   #9
Milo's 72
Milo's 72's Avatar
You know what's funny.yall are lowering your trucks and I see people raising there cars on 24s.to me a car is a car why raise it like a truck.i use my truck for its intended purpose.but I like seeing yours lowered just not mine.cant haul a cord of wood on bags.
Milo's 72 is offline   Reply With Quote
