Old 03-15-2014, 02:35 AM   #1
luvbowties
luvbowties's Avatar
Question Can hub-centered wheels work here?
Found a nice set of newer Chevy, SS pickup, all steel, thin-center wheels, but the hub-center is too big for my front rotors:don't know if they were hub- or lug-centered originally--kinda leaning toward hub-centered. Lugs are 1/2-inch diam.
Can such wheels be installed, securely centered, by using proper lug nuts that have a taper steep enough to lug-center them? They fit pretty flat against the flat of the rotor, with no noticeable wobble; yet the lug holes have flares that are maybe 1/32 to 3/64-inch back from the flat of the rotor, making me think the tapered-lug nuts with the lug-centered approach is doable. But frankly, I've never experienced it.
Ideas, please?
Sam
luvbowties is offline   Reply With Quote
Old 03-15-2014, 03:19 PM   #2
66 C10 383
Re: Can hub-centered wheels work here?
Lug centered is a totally acceptable way of mounting wheels. I've seen a bunch on heavy duty trailers rated at 10,000#+ that only have lug centered wheels. Just make sure your lugs stay tight and you'll be fine.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 03-15-2014, 04:15 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
A buddy of mine in the business says all wheels are lug centered since you can remove the wheel from the hub! lol
Old 03-15-2014, 05:14 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think they look funny because the center of the wheels are pushed outward and not centered in the wheel rim.
The hub centric wheels have a small center hole that will need to be machined to a larger size to fit over the stock hub.
The 63-66 have 7/16 lugs and the 73 and up have 1/2" lugs also so those won't fit right either unless you drill out your drums to accept the larger
Lugs
Whatever you do good luck
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-15-2014, 08:20 PM   #5
gimmy 64
from what I have read the original wheels are hub centered and all aftermarket wheels are lug centered
gimmy 64 is offline   Reply With Quote
