Old 03-15-2014, 06:04 AM   #1
jcd9730
jcd9730's Avatar
Radiator support?
So I'm trying to fix up a smashed up front end, and this piece is pretty badly bent so I need to replace it. I don't really know what that part is called, but the bolt for the radiator support goes through there (one on each side). I've been trying to find one, but I don't know what its even called.
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 03-15-2014, 06:05 AM   #2
jcd9730
jcd9730's Avatar
Re: Radiator support?
I'm sure I could find one at a salvage yard, but it would be a pain to take the radiator support out and grind the rivets out so I'd rather just buy one somewhere
Josh
Old 03-15-2014, 07:07 AM   #3
Boog
laying low
Boog's Avatar
It's just a radiator support mount. You could heat yours up and bend it back around and put a bolt and washer through that one hole the rivet pulled through or most salvage yards still use acetylene torches. They could burn another one off of a frame for you in a jiffy. It's not a big seller item.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-15-2014, 07:10 AM   #4
jjzepplin
jjzepplin's Avatar
Radiator support mount frame bracket? They come up for sale here now and then.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-15-2014, 07:52 AM   #5
GMCPaul
PM Sent
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
