Old 03-15-2014, 04:16 PM   #1
grs
Shock relocation kit?
If I lower the rear of my 64, 4 inches do I need to put a shock relocation kit on it? And an adjustable tracking arm?
grs is offline   Reply With Quote
Old 03-15-2014, 04:19 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Shock relocation kit?
I say 5" or 6" drop needs them.
Never done a 4" drop.
Look at your shock angles when you are done and check if the rearend is still centered in the frame.
That will tell you the real answer.
Keith
Convert to disc brakes.
Old 03-15-2014, 04:45 PM   #3
grs
Old 03-15-2014, 10:15 PM   #4
SCOTI
SCOTI's Avatar
I would do the relocating brackets if the 4" drop is w/just springs. Blocks & springs I wouldn't bother.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-16-2014, 12:03 PM   #5
grs
Why doesn't blocks, and springs need relocation brackets if it is 4 inches lower?
Old 03-16-2014, 12:11 PM   #6
grs
Old 03-16-2014, 05:35 PM   #7
67stepper
67stepper's Avatar
How about if you replaced the stock shocks with lowering shocks do you still need the reloctation kit?
67stepper is offline   Reply With Quote
Old 03-17-2014, 09:16 AM   #8
SCOTI
SCOTI's Avatar
Shorter shocks = possible less travel regardless of actual available travel. Relocating the mounts allows better angles & more travel. Aftermarket shorter shocks can (and will) work. But, OE replacement shocks would still be easier should there ever be a need to replace or upgrade. You always want the most travel possible w/any shock or spring for the best possible ride.
Drop blocks in a truck-arm application don't impact shock travel since they only alter the position of the rear end housing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
