Old 07-25-2003, 11:35 AM   #1
Estanley
Estanley's Avatar
OT: S10 Cooling
I know this is not 67-72 related but there is too much knowledge aroung this board to not ask this question. I've got an S10 with a 350. I'm using the 4.3 rad. that has been boiled out at the rad. shop. I've got two electric fans (10" and a 12") that I am running as push on the front side of the rad. They are on a thermostat and are set to come on around 200 degrees and I have a 195 degree thermostat. I am planning on putting in a 180 this weekend but I don't think it will help my problem.
Alright, here's the problem. Running down the hwy. it will run right at 195 but if I stop or sit at a red light it starts to creep up. The longer I sit the higher it will go. Running around town it wants to run around 205 to 210. The highest I have let it get is about 230 degrees.
Any help PLEASE!!!!!!!!!!
Estanley is offline   Reply With Quote
Old 07-25-2003, 11:48 AM   #2
miket
miket's Avatar
I would say airflow....if it stay's cool at highway speeds but creeps up at idle.....my opinion would be airflow...not sure about the effeciency of pushers....do you have a shroud? What CFM are the fans rated at?
Is the radiator new? Has it been flushed lately? How about age of coolant?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 07-25-2003, 12:08 PM   #3
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I second airflow. Pushers are not as efficient at moving air though a radiator as puller fans,(or so I read somewhere) but nothing comes close to the air moved by an engine driven fan. I have the same problem on my '72, and it's because of the 13" flex fan i have(getting replaced this weekend along with a shroud). It was a lot worse when I had electrics on it.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 07-25-2003, 04:43 PM   #4
Estanley
Estanley's Avatar
ttt
