My son....
My 3 year old son just told me he he put a paper towl down into my gas tank.. He said he put black tape and a paper towl on a stick to see what was in there...
#2 | |
Re: My son....
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Who Me?
Re: My son....
You might find a matchbox car in there too...
You could pull the sending unit out and take a look from there. You may be able to fish it out from that hole.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: My son....
Thanks!! Should I drive it knowing that it's in there? I'm wondering if it will clog up and doesn't get gas to the engine...
![]() Join Date: Sep 2009
Re: My son....
don't drive it or start it!!!!!!!!! pull the sending unit and see what you can. if you start it or run it you can have small bits of what ever in your fuel lines carb fuel pump --very costly!!!
![]() Join Date: Aug 2010
Re: My son....
Aww, aren't they precious
![]() If the paper dissolves, I'd slap a cheap temporary inline filter on there before any muck gets in the carb, or you'll be pulling that too. Good luck and go easy on the little fella. |
Re: My son....
Now that is funny, cool he told you. Take the tank out or crap will make it's way to the carb eventually and then pulling the carb too.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Re: My son....
Thanks for the help! Yes my boy is funny.
I'm just glad to be here!
Re: My son....
this will make for a good memory when he gets older...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Re: My son....
I had a 66 that had a new paint job. My son was about 5. He went into the garage and some how knocked a can of spray under coating on the floor. It sprayed all over the side of the truck. I never screamed at him because it was an accident.
Post Whore
![]() Join Date: Mar 2013
Re: My son....
Pull the tank and dump the fuel in a 5 gallon bucket, and see if you can get that stuff out. The dump two cans of sea foam in along with a couple gallons of fresh gas and shake the tank real good so it'll clean it. After that, re-install with a locking gas cap. I'm sorry I have to admit this but...I blew up laughing when I read your story.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
