Old 03-15-2014, 11:32 PM   #1
albertgen
1978 C10 305 5.0L Custom deluxe th350 transmission leak
My truck is leaking transmission fluid from the weep hole, what should I do? There has been a lot coming out of that hole, the seal on the tail housing is fine. Any ideas?
albertgen is offline   Reply With Quote
Old 03-16-2014, 09:19 AM   #2
Re: 1978 C10 305 5.0L Custom deluxe th350 transmission leak
There is a seal inside of the transmission tail shaft that is probably worn out. There are different versions of T350, some didn't use a weep hole in the front yoke. When I changed transmissions in mine, I also changed to a none weep hole yoke.
Old 03-16-2014, 09:52 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Welcome to the site. Is the seal new?
Here is info on the seal: http://www.73-87.com/7387garage/drivetrain/yokeleak.htm
Check the vent line is clear. If the vent line is clogged, pressure builds up blowing out seals.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-16-2014, 07:17 PM   #4
albertgen
I noticed a little bit of leaking where the the tailshaft housing bolts on. I read and seen the article above about the cup and O ring. I've read that a l;ot of folk had no cup or O ring? Is that true? I've had my truck in the garage for the winter while trying to wire brush the rust off, so it has been sitting for a spell. I did install a new transmission mount, the old one was wore all the way down, so the new mount lifted the tail housing a couple of inches. I also found a website that offers a plug for that weep hole. I don't know about the vent or how to check it. Thank you, Al
