Old 03-16-2014, 02:24 PM   #1
Jer64
Jer64's Avatar
L33 & 4L60E swap
Here's my swap, its an 06 L33 with 40,000 miles and 4L60E with 19,000. I'll be running a Griffin LS swap radiator and a Boyd Welding EFI tank. I have a PSI wiring harness and Dakota digital VHX gauges waiting to be installed. Unless I'm overlooking something, I should have most of the major components purchased already.
Now, I just have to decide on headers, a new oil pan, the fuel lines/filter and tranny lines. Here are some pics of where I'm at now, feel free to leave to some suggestions as this is my first LS swap!
wiring harness mocked up
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=587028
Jer64 is offline   Reply With Quote
Old 06-30-2014, 01:31 AM   #2
Jer64
Jer64's Avatar
Re: L33 & 4L60E swap
here's some updates on the swap so far. got the fuel tank installed and fuel lines ran. first time putting together AN fuel lines, hopefully there won't be any leaks, but I'm getting closer to fire it up!
[IMG][/IMG]
[IMG][/IMG]
My build thread:
Old 06-30-2014, 10:00 AM   #3
oldman3
oldman3's Avatar
Nice looking job, chassis is sweet...Jim
oldman3 is offline   Reply With Quote
Old 11-07-2014, 12:04 AM   #4
Jer64
Jer64's Avatar
thank you Jim!
My build thread:
Old 11-07-2014, 12:08 AM   #5
Jer64
Jer64's Avatar
I have the PSI wiring harness all hooked up, but the motor is not turning over. I was wondering if there is something I might be missing, I've read a few posts about running a wire from the junction box on the radiator support to the starter, but that didn't do it either. any suggestions, from the guys who know what they're doing??? thanks for the input!
My build thread:
Old 11-07-2014, 08:51 AM   #6
dec010974
dec010974's Avatar
good morning. nice swap you have there. it looks very nice and clean. first thing I would do Is check for power, ignition power and 12v power with a test light. check the relays, injectors plugs, maf sensor plug, coil packs plug, starter, transmission plug. check all your source and see what has power. also, the starter is responsible for cranking, turning the motor over. I hope this helps. clark.
dec010974 is offline   Reply With Quote
Old 11-07-2014, 10:10 AM   #7
ls1nova71
ls1nova71's Avatar
Isnt turning over "cranking" or isnt starting (running)?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-07-2014, 12:17 PM   #8
Jer64
Jer64's Avatar
thank you for the quick responses, looks like I have a few more things to check! the starter isn't engaging so its not cranking. the fuel pump turns on and I have power to the pcm relay with 12V and cranking. thanks again for the quick responses!
My build thread:
Old 11-07-2014, 05:40 PM   #9
ztk123
Make sure you have the purple wire from your ignition system connected the the small lead on the starter. Great looking project by the way!
Mike
ztk123 is offline   Reply With Quote
Old 11-07-2014, 06:09 PM   #10
Jer64
Jer64's Avatar
Mike
Looks like that's what I was missing! Hooked the purple wire up to the small lead and it'll turn over now! Thank you!!!!
My build thread:
Old 11-23-2014, 01:24 AM   #11
70blackfish
who makes those headers??? i like em
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 11-23-2014, 02:30 AM   #12
Jer64
Jer64's Avatar
Thanks! They're Hedman part # 45666 for c10 ls swaps
My build thread:
Old 11-23-2014, 02:36 AM   #13
Jer64
Jer64's Avatar
here's a quick video, I got the motor started up today!
[IMG][/IMG]
My build thread:
Old 11-23-2014, 11:03 AM   #14
oldman3
oldman3's Avatar
Looks great and sounds super....Jim
