71 Chevy Seat Suggestions
Hello,
I have a 1971 short bed Chevy C10 that is ready for interior work. I want to do a bench seat and installation of shoulder belts is a possibility for this old truck. Any suggestions on some after market seats? I will also be relocating the interior gas. Any suggestions for this move would be also greatly appreciated. I am new to the forum. I will get some pics of old blue up when we get started working on it. Ready for some summer weather to get started working on this project here in Waco, TX. |
Re: 71 Chevy Seat Suggestions
I am eager for these answers too.
I want (for now) to keep my in cab firebomb/gas tank but put in a bench seat WITH head rests. I don't like leather but shoulder harnesses would be nice. |
Mid 90's early 2000 had a really nice bench in some of the single cab trucks.
That would be a good start. I used a relocate kit from brotherstrucks.com You do have to do some shaving on a support bracket under the bed. But it's pretty easy. Here is a link, https://www.brotherstrucks.com/prodi...number=GTPDS72 I am a little jealous i forked out $300 and it's one sale now for 189$ That's a great kit. Are you running carb or efi or ls? |
You can also consider what I did. I wanted buckets but still wanted a third seat. 2011 2500 seats two buckets and center console (jump seat). They for quite nicely and have the options to bolt the seat belt to seat which is nice.
Here's another look
Here is the lid closed
![]() Join Date: Dec 2013
Like the 2011 seats! What did you have to do to the floor to mount them? Photos?
I just had to drilled a few holes. I used the stock mounts that came one the seats. I had a new carpet kit so I used a hole punch to make a whole in the carpet. Then I used some some brass grommets to keep the loop carpet from fraying.
I used a stitching all to cut openings in the carpet to hide the front legs on the jump seat here's a close up.
Pretty decent cover up using a stitch lock method and some black canvas.
Sorry for all the posts I'm using my phone and they will only let me post one photo at a time. Need to find an app that will make this work a little better. These big tabs are what are covered
Then topped it off with my original door sill plates powder coated gloss black and stainless screws.
#13 |
Looks clean! How is the height with the 09 brackets? Does it give you a little more room between the steering wheel?
#14 |
I would say its about the same. I can measure tonight when I get home.
#15 |
I'm sticking with the carb in this truck since it still has the original engine.
#16 |
So where did you put the filler neck?
#17 |
I plan on putting mine behind the drivers rear tail light. Right now I have it temp mounted in the wheel well behind the drivers rear tire.
Here is a thread that explains the filler tail light. http://67-72chevytrucks.com/vboard/s...d.php?t=222461 Really nice idea! There are other ideas I've seen for the side marker too. You can cut a whole in the bed and use a standard door or create one. But that thread is probably the coolest one. Similar to the old tri fives tail light filler back on my grandfathers 55 bel air. |
#18 |
Ok measurements on the seat. 57" wide from passenger seat to drivers. Buckets are 13" tall a comfy rake with the seat all the way back would give you about 13" of clearance from the cluster to the seat edge. The center console (jump seat) runs 10" tall with 11" of clearance to the a/c panel.
#19 | |
I want a center console, but my dogs would enjoy having a bench.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
#20 | |
#21 |
Those seats look killer in your truck nice work!!
#22 |
