Old 03-16-2014, 03:19 PM   #1
NEWBIEC10
NEWBIEC10's Avatar
Rear lowering springs?
Do you need a adjustable panhard bar with 3" drop springs? I made some 2" lowering blocks and got longer U bolts so now I want to do 3" drop springs to = 5" of drop.
Also would my shocks still work or do I need different ones?
NEWBIEC10 is offline   Reply With Quote
Old 03-16-2014, 09:52 PM   #2
NEWBIEC10
NEWBIEC10's Avatar
Re: Rear lowering springs?
Anyone?
Old 03-17-2014, 08:36 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You will need an adjustable track bar of some flavor. That 5 inch drop is gonna shift the rearend to the side a noticeable amount.
Old 03-17-2014, 10:38 AM   #4
NEWBIEC10
NEWBIEC10's Avatar
Thanks for the info Tx. With your personal opinion, would you do 3" drop springs and 2" lowering blocks? Or just a 5" coil drop? What would ride better?
Thanks TJ
Old 03-18-2014, 06:45 AM   #5
Tx Firefighter
I'd go with the 5" spring.
Reason why, a 5" spring costs the same as a 3" spring. And, in the future it gives you the option to add a 1 or 2 inch block if you decide you want to go down further.
Old 03-18-2014, 08:00 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Bag it!
If you ever want to tow something other than a small lawn mower trailer, bag it!
the 3+" lowering springs are rather light duty and wont support much weight on the hitch or in the bed.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2014, 10:36 AM   #7
NEWBIEC10
NEWBIEC10's Avatar
Cool. Thanks for the info. I'll be ordering a 5" drop kit.
