Old 03-16-2014, 03:44 PM   #1
heehawracing
heehawracing's Avatar
project parts truck
i have been parting out 67 72 trucks for about 10 years now and i have sold tons of parts on this board now its time to build one. i have realized that these trucks are getting hard to find with little to no rust. so i am going to start building a few of the good ones i find so i started looking for a good cab i found a 1 ton 157 wheel base truck with very little rust so i am going to use the cab and build a short bed 1/2 ton nice driver with cold air lower it 5/7 with 20 inch torq thrust
heehawracing is offline   Reply With Quote
Old 03-16-2014, 03:46 PM   #2
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Re: project parts truck
Cool, sounds like a fun project!
Tropical Snowstorm is offline   Reply With Quote
Old 03-16-2014, 04:09 PM   #3
heehawracing
last weekend we got the cab off and this weekend i built a cab dolly to roll it around on. i also got out the 4 speed column. this week i am going to take out the clutch pedals and put in an auto. brake pedal.
Old 03-16-2014, 04:21 PM   #4
flashed
That is one of the nicest cabs Ive seen ,Im in on your build . If you come across a decent flat bed for a 1 ton keep me in mind .
flashed is offline   Reply With Quote
Old 03-16-2014, 05:17 PM   #5
heehawracing
i will thanks
Old 03-18-2014, 08:46 PM   #6
heehawracing
im going to keep it with the patina look i just will have to find a bed to match or paint one to match. this week end i am going to get it ready for the tilt and change the pedals.
Old 03-18-2014, 09:12 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Cool truck.
I would have liked to had it as a 1-ton truck.
Keith
Convert to disc brakes.
Old 03-18-2014, 09:36 PM   #8
heehawracing
thanks... it was fun to drive but that 157 wheel base was just to long for me
Old 03-18-2014, 09:52 PM   #9
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Nice cab for sure. I'm. In for this build
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-29-2014, 02:30 PM   #10
heehawracing
i bought a 72 short bed to get the frame and rearend it took about 15 min. to get the cab off. i am going to take the frame apart to paint it and c notch it.
Old 03-29-2014, 07:32 PM   #11
flashed
Looks like a good start .
Old 04-12-2014, 09:12 PM   #12
heehawracing
well i have talked myself out of the patina look so i am going to get it ready to paint, i bought some goodmark inner and outer rockers they did not fit at all so i got some from gmc pauls. the rockers from them are tri plus they fit great. its easy to line up the doors when you have rust free gm doors.
i think i am going to paint it the same color and leave the original paint on the inside. i have ordered my lowering kit c notch a trailing arm cross member, i hope to get the frame painted soon.
Old 04-13-2014, 04:07 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Looking good. I've found everything but inner door bottoms to be great from Triplus/keyparts. Have had hit or miss success with goodmark/tabco/others....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-27-2014, 01:24 PM   #14
heehawracing
well i have got one of the top running lights shaved one rocker in. i still need to get the firewall shaved and one cab corner done. i got the frame almost all the way down. i have ordered most of the lowering parts so i am going to try to get the frame painted soon. i was going to buy a complete new bed but i have some real nice 67 bedsides so i guess i will use them and buy a new floor i have almost all the body parts now i just need time to work on it..
Old 04-27-2014, 04:10 PM   #15
resto newbie
resto newbie's Avatar
When drilling out spot welds do you drill through both layers of the sheet metal, or just through the first layer to free the part that needs replaced?
Chad
1967 Chevy C10 "Project DV8ED"
1994 Nissan 300zx convertible
2004 Chevy 2500HD crew cab 4x4
resto newbie is offline   Reply With Quote
Old 04-27-2014, 04:15 PM   #16
heehawracing
just go through the first layer then the metal your welding back to doesnt have a bunch of holes in it.. i use a spot weld cutter that looks like a small hole saw you can buy them at habor feright for about 7.00 and they work just as good as the 25.00 ones from any were else
Old 04-27-2014, 04:29 PM   #17
resto newbie
Thank you for that! I have always wondered.
Chad
