Just like to part out trucks!!
steering column parts
Most are automatic, one is 3 speed, one is 4 speed. Would like to sell as package deal but would sell individual parts
For all small parts, no tubes or shafts $160 shipped. NO TILT parts!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-16-2014 at 07:32 PM. |
Re: steering column parts
49
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
54
59
64
last of little parts
These parts are not included in package deal
First 2 pics of parts on this page are all sold
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-26-2014 at 08:09 AM. |
I may have the tubes sold locally, I will know for sure tonight
Randy i know this is unrelated but would you happen to have a set of trailing arms ? If so shipping to 76008.
84 step side 87 swb |
![]() Join Date: May 2013
Randy how much for the blue 4speed collar shipped 32968. Iam converting from a 3 on the tree to a fpoor shifter and bc want to eliminate the shift handle. Thanks John
![]() Join Date: Mar 2011
Randy,
if you dont sell the whole lot i would like a washer & spring and the intermediate nut & bolt thanks Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Calvin, sorry none right now
JOhn, $22 shipped Jess, $16 shipped Thanks Randy
#13 |
ill do the MO tomorrow thank you
#14 |
Thanks, but I will pass I found a whole 4speed column.
#15 |
![]() Join Date: Oct 2012
Randy, I am interested in the below parts, basically a bunch of backup parts. I need them correct for a 70 auto non-tilt, so please correct me if I messed up. Would $45 get it shipped?
1) Horn contact assembly - are these the more shallow cups for 70? (pic 5 lower one) 2) Under column slide cover (pic 6 good blue one) 3) Cancel cam (pic 7 good one) 4) Switch support (pic 8) 5) Neutral switch (pic 9 good one) 6) Upper bearing (pic 13) 7) Shaft nut and washer (pic 14) 8) Spring and washer (pic 15) 9) Shifter handle pin and gear indicator with housing (pic 16) 10) Do any of those fiber optic lines have the small orange pointer for a 70? Most look like the larger type (pic 17) 11) set of bolts\screws for one column (Pic 22) 12) Lower shaft bolt (pic 25) 13) shaft with lover bearing (pic 28 good teeth) Thanks Jim |
#16 |
Price on a canceling cam (67) in good condition shipped to 98387?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#17 |
Jim, let me get all that in one pic and check shipping.
swamp rat, none for a 67, these are all 69-72, I'm not sure the difference Thanks Randy
#18 |
JimH2828, Jim, here ya go. I have it all except the fiber optic end is faded. I'd go $50 shipped for it all, I usually sell the shafts alone for $25 shipped
#19 |
Randy, a couple of corrections to your picture.
1) Need to add a cancel cam (post 2 pic 2 good one) 2) In post 5 pic 2, in addition to the 3x horn screws I was interested in those other screws and pin thingys. 3) I don't need the lower steering shaft, I was wanting the main steering shaft with a lower bearing (post 7 pic 2) Thanks for gathering it all up and sending the pic, Jim |
#20 |
Jim, sorry missed under stood on shaft, I sold all my long shafts and lower bearings already. I'm going to pick up a truck after work, I will get pics of other stuff tonight, sorry. Thanks Randy
#21 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
How much for these rings that screw to firewall?
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
#22 |
Jim, here ya go, only have 2 of the pin thingys. $43 shipped for all
#23 |
Kevin, $26 shipped for all of those. Thanks Randy
#24 |
Randy, funds and PM sent.
Thanks Jim |
#25 | |
The 4spd is that column shhift or on the floor. Im looking for non tilt column for 68. I need the following: 1) Horn contact assembly - 2) Cancel cam (pic 7 good one) 3) turn signal with red knob hazard flasher 4) Upper bearing (pic 13) shipped to 98682 5) shaft with lower bearing (pic 28 good teeth)
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
