Hot Rods For Life
I need a part number Maybe? Anyone? Turn signal swith behind steering wheel
Yeah.......for the Turn signal swith behind steering wheel. The plastic piece the actual signal handle connects to. I traced this to be the culperit(sp) of my no start problems. Sometime I have to turn the key with the signal on to start the truck.
67-72 Addict!
This is the number on my receipt from my local Chevy dealer:
0001972751. Hope this helps!. I refused to believe this switch could cause so many probs. Best thing I ever replaced to avoid all the headaches I was having.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
its all about the +6 inches
I can not see how the turn signal switch would keep it from starting.
If you are talking about the actual part that the turn signal lever is attached to, the one that went in my 69 GMC with non tilt(if that matters) was 1894852.
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
#5 | |
Hot Rods For Life
Zumo,
You did fix that leaking gas tank right? Just checking Electric shorts and gas fumes don't mix well.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
