Old 03-17-2014, 01:13 AM   #1
71 customcamper
Fuel issues
I just bought my first squarebody. It's an 86 one ton. I replaced the carb and fuel pump along with the fuel tank valve. The fuel bleeds off within 5 min of turning off the truck is there anyway to fix that or something that I'm missing? I live in California and I'm not really sure where to go to ask but do you have to keep the return lines to the tanks functional for emissions purposes? Because I'd like to convert to a electric fuel pump and get rid of that valve and just use one tank, but I'm not sure if I should get the one with the return line built in or the one with out the return line. Thanks for all the help in advance.
71 customcamper is offline   Reply With Quote
Old 03-17-2014, 03:25 AM   #2
mrolds88
Re: Fuel issues
When you say the fuel bleeds off does that mean that the fuel gets sucked back out of the carb and back to the tank? If so, I think you have a bad fuel pump. They have one way valves in them and it sounds like at least one of them is leaking.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-17-2014, 09:35 AM   #3
71 customcamper
Re: Fuel issues
Yeah it leaves all the fuel in the bowl but there's none in the line so it dies after 3-5 seconds after you start it. My old fuel pump did the same thing that's why I replaced it. Is it worth it to invest in a Holley or edelbrock fuel pump rather than the napa auto parts pumps?
