Old 03-17-2014, 02:59 PM   #1
JIM1009
409 in 60-66 pick-up
Has anyone put a 409 in a 60-66 pick-up? Im thinking of putting one in my 63 and was wondering what headers will work. I dont have any exhaust manifolds. Thanks
JIM1009 is offline   Reply With Quote
Old 03-17-2014, 03:07 PM   #2
1963c-10
1963c-10's Avatar
Re: 409 in 60-66 pick-up
Have seen plenty with the 348's & 409's , but they all had the cast iron manifolds. Mostly in medium-heavy duty trucks
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-17-2014, 03:49 PM   #3
JIM1009
Thats what i was thought. Since i dont have any manifolds ill probably try some block huggers or shortys. Just wondering if someone has tried this. Thanks
Old 03-17-2014, 03:56 PM   #4
60-66
60-66's Avatar
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-17-2014, 04:12 PM   #5
MikeN
MikeN's Avatar
409 into a 60-66, that would be a really cool swap! I'd encourage you to search around for a nice set of used factory manifolds. I recently took the headers off the 350 in my 64 C10 and went with the factory rams horn style manifolds. Headers are just a pain...fighting with the clutch linkage, starter and starter wiring, oil filter access, etc. I'm much happier with the manifolds.
MikeN is offline   Reply With Quote
Old 03-17-2014, 04:13 PM   #6
JIM1009
Wow! That looks great. Maybe i should just look for some cast iron manifolds. Is yours a stock truck motor?
Old 03-17-2014, 04:20 PM   #7
JIM1009
Yes the manifolds make more sense. I was thinking maybe better flow through headers.
Old 03-17-2014, 04:43 PM   #8
1963c-10
1963c-10's Avatar
Im sure someone makes shorty headers for the 348/409 too.
Old 03-17-2014, 06:49 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
WOW! That blue and balck 409 looks factory in that C-10! My congrats to whoever restored that!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-17-2014, 07:16 PM   #10
Old Truck Man
Old Truck Man's Avatar
Lots of bigger trucks had 409 & 348 engines. The truck engines both the 409 & 348 have the dipstick on the passenger side of the engine. the car 409,s have the dipstick also on the pass side the car 348 has the dipstick on the driver side. the truck engines have a notch on the cyl wall to lower the compression. Back in the day they where kinda like a flathead ford. If they where good they where great. Overheat them one time and you had cracked heads or block or blown head gaskets. Really cool looking engines. I had a 348 with tri power carb,s and crome valve covers. I too would vote for stock cast iron exhaust manifolds.
Old Truck Man is offline   Reply With Quote
Old 03-18-2014, 12:05 PM   #11
63burban
Chevy addict
I have a 348 in a 1965 C30 that I will be pulling out, not sure whats wrong with it but it won't turn over. I haven't had a chance to check it out. It will be up for grabs when it comes out.
63burban is offline   Reply With Quote
Old 03-18-2014, 12:09 PM   #12
1963c-10
1963c-10's Avatar
Send it my way....I'd love to put it in the 63 short fleet!!!
Old 03-18-2014, 12:11 PM   #13
63burban
Chevy addict
Most likely need to re build it, could get expensive. If you are serious, PM me.
Old 03-18-2014, 12:51 PM   #14
1963c-10
1963c-10's Avatar
PM sent
