Old 03-17-2014, 05:50 PM   #1
tismy55
Intermediate Steering Shaft
The boot is torn on the upper part of the intermediate shaft. My question is does this boot hold grease for that knuckle ? also can it be replaced? Would a driveline service be able to fix it. One last question would that torn boot if all the grease is gone cause loose steering? Thanks My Truck is a 89 c2500
tismy55 is offline   Reply With Quote
Old 03-17-2014, 07:05 PM   #2
c10sport
c10sport's Avatar
Re: Intermediate Steering Shaft
Yes, loose steering is one of the biggest symptoms of a bad lower steering shaft.
I'd just replace it. Here's what I did, used a shaft from a 1988-96 Jeep Cherokee I got for $5 at a junkyard. It took longer to take it out of the Jeep than it did to modify it to be put in the truck.
All you have to do is heat up the middle where the two halves meet to get the plastic bushings out so it will collapse. It bolts in place of the original shaft and uses U-joints rather than fabric joints.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 03-17-2014, 07:32 PM   #3
tismy55
Are you talking about heating the 2 halves of the Jeep shaft or the silverado halves. Thanks
Old 03-17-2014, 07:53 PM   #4
c10sport
c10sport's Avatar
The Jeep shaft. There's two bushings inside that keep it from collapsing by hand. Once they are out, you can put some RTV in their place and the shaft will collapse and can be installed in the Silverado. The Silverado shaft collapses easily to come out.
To get one out of a Jeep, you can either get lucky and find one that has already had the column or box removed or you can take the three bolts out and drop the box. There's two bolts holding the Jeep shaft in place, one at the column and one at the box.
Jay
Old 03-17-2014, 07:56 PM   #5
c10sport
c10sport's Avatar
You can see in the picture where mine is slightly discoloured where I heated it up.
Jay
Old 03-17-2014, 08:16 PM   #6
tismy55
Oh yes i see it now .I'm going tomorrow and get a jeep shaft. I appreciate your help. Thanks
Old 03-18-2014, 04:05 PM   #7
tismy55
Jay, heating and collapsing the bushings on the Jeep is that so you can adjust the shaft to the correct length to fit the silverado? It doesn't make the shaft a loose does it. Thanks
Old 03-18-2014, 07:49 PM   #8
c10sport
c10sport's Avatar
No, it doesn't. You can put some RTV in place of the bushings if it seems loose. I never did on my S10 when I put the Jeep shaft in and it wasn't loose at all.
Jay
Old 03-24-2014, 11:31 AM   #9
Metal
Metal's Avatar
I drilled and tapped a hole.. Then just used a bolt to keep it tight....
"If at first you don't succeed use more duct tape" Red Green....
Danger --if you meet it promptly and without flinching -- you will reduce the danger by half. Never run away from anything. Never!
-Winston Churchill
A few of my holsters.............
Metal is offline   Reply With Quote
Old 03-24-2014, 11:37 AM   #10
tismy55
Metal, did you use a jeep shaft as well .
Old 03-24-2014, 11:42 AM   #11
Metal
Metal's Avatar
yes sorry... After I melted out the plastic it was a little loose ..
-Winston Churchill
Old 03-24-2014, 12:49 PM   #12
tismy55
where on the shaft did you drill the hole ? Thanks
Old 03-24-2014, 01:22 PM   #13
Metal
Metal's Avatar
bout a 1 inch up from the end of the female half of the shaft.. Then I slid the male end in and tightened the bolt..
-Winston Churchill
Old 05-27-2014, 08:21 AM   #14
jammer3096
Will the jeep shaft fit a DD fitting at steering column. Or is it a spline? Also are the spline counts the same at gearbox?
jammer3096 is offline   Reply With Quote
Old 05-27-2014, 09:07 AM   #15
tismy55
Got mine installed works great . just heated it up and it collasped and fit perfect no holes to drill on mine.Thanks guys.
Old 05-27-2014, 09:12 AM   #16
jammer3096
What year of truck have got?
Old 05-27-2014, 01:28 PM   #17
tismy55
89 silverado c2500
Old 05-27-2014, 09:20 PM   #18
jammer3096
does anyone know how to tell if your column needs rebuilt
