Old 03-17-2014, 07:35 PM   #1
rdbman
72 c-10 into 68
Hey people I am trying to put a 1968 front end sheet metal only on to my 1972. Will it work and only change out core supports. Thank you very much
rdbman is offline   Reply With Quote
Old 03-17-2014, 08:10 PM   #2
ochre70
Re: 72 c-10 into 68
From what I understand only the inner fenders will swap between a 67/68 front end and a 69-72 front end. I'm sure others will chime in on this. I believe its been covered many times if you'll do a search also.
1970 Ochre & White C10
ochre70 is offline   Reply With Quote
Old 03-17-2014, 08:51 PM   #3
rdbman
Re: 72 c-10 into 68
no it wont work I have searched this site on this matter and i only seen the swap between a 68 and a 71 can i put a whole clip from my 1968 on to my 1972. i have everything to do this with i just wanted to buy a new core support and new inner fenders thanks so much
Old 03-17-2014, 09:04 PM   #4
hugger6933
Re: 72 c-10 into 68
The inner fenders are the same throughout the production run 67-72. The core support is different for the 67-8 and the 69-72. So there will have to be a core support change along with the hood and fenders. Jim
hugger6933 is offline   Reply With Quote
Old 03-17-2014, 09:36 PM   #5
rdbman
Re: 72 c-10 into 68
so make sure i have this straight change my core support and my fenders and hood? i do have the fenders off my 68 and the hood off the 68, plus the hood latch off the 68 i will change the mounting bushings for the core support also is that right
Old 03-17-2014, 10:13 PM   #6
low&slow
Re: 72 c-10 into 68
I've only been told from this forum that all you need is the front clip and it all will work.
Also for the core support, the only difference is the headlight buckets.
low&slow is offline   Reply With Quote
Old 03-17-2014, 10:54 PM   #7
colgad
colgad's Avatar
Re: 72 c-10 into 68
The core support is different, it has fasteners for the splash pan, only the 67/8 has a splash pan
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 03-18-2014, 09:45 PM   #8
low&slow
Re: 72 c-10 into 68
You are correct. Forgot about that. But, if you're not going to run a splash pan (like myself), then you could use the 69-72 core supports with the only difference being the headlights
Old 03-19-2014, 02:56 PM   #9
cheviss427
Re: 72 c-10 into 68
Hello, If i'm getting this right, you would need different headlight buckets.....which ones? The 68 buckets are a 1/4" off. Thanks.
cheviss427 is offline   Reply With Quote
Old 03-19-2014, 03:58 PM   #10
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Re: 72 c-10 into 68
Yep lot of stuff different , we need to write an article with parts diagram on this , making a 69 to 72 look like a 67 or 68 is about the most popular mod nowadays ,,,,,, im flattered LOL
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-19-2014, 08:31 PM   #11
low&slow
Re: 72 c-10 into 68
That's correct. You'll need different headlight buckets if you are using a 69-72 core support. If you use the original buckets on a 69-72 core support with a 67-8 grille, your headlights will be off and not centered in the hole of the grille
Old 03-19-2014, 10:54 PM   #12
In The Ten Ring
Re: 72 c-10 into 68
I have a 67 hood, grill, and both front fenders if you are interested. They are in my dad's garage attic (hood is outside on blocks and under a tarp). Just PM me.
In The Ten Ring is offline   Reply With Quote
Old 03-23-2014, 08:17 PM   #13
rdbman
Question Re: 72 c-10 into 68
Which headlight buckets will work if I use 72 core support on a 67 front grill and fenders
Old 03-24-2014, 03:39 PM   #14
low&slow
Re: 72 c-10 into 68
The 69-72 supports have a bucket the bulb sits in and that bucket is mounted on a spacer type thing that is spot welded to the core support. Take those off with an air hammer or something. Once you do that, you'll have a 67-8 core support.
If you're going to use a 72 core support, as mentioned above, you won't be able to use the splash pan.
Old 03-24-2014, 06:52 PM   #15
rdbman
Re: 72 c-10 into 68
what do you mean splash pan? inner fenders?
